Question Xbox Power Supply issue how to fix it?
Josephraj
I Have a xbox one console which is from USA, I bring it to India , yesterday I try to switch on the plug after connection tv with xbox console , A spark occur in the plug holder and the power shutdown in my house only, (power trip ), Again I try by power extension cable again the same fault occur. Can anyone please guide me, how to fix this issues .
Muadib
18,127
912
If you plugged a USA Xbox one without a voltage converter, it's very likely you fried it. India uses 230V.
