Xbox Component Cable for HDTV
exorr
Hi All,
Can someone recommend a nice high-quality Xbox HDTV Component cable? I've heard the MS AV Pack isn't very good.
Looking to buy one in the next few days.
Thanks!
Ethan
Damn. Do people not read at all anymore? OP has been with us since 2001.
Ask in the official Xbox thread. Or in the Peripherals section. Or in the General Hardware. Or even in Video. Crap, try Hot Deals too.
Does anyone here know how I can overclock my gigahertz???
Where is this Xbox thread? I see an Xbox 360 thread, I'm not asking about the 360.
What is the problem with posting this in Off Topic, this topic is for anything, that is the point, is it not?
If I ask in Hot Deals, I get a ton of crap...
I want to know too (also want component cable for xbox1).
And shortlickens,
I fail to see how this doesn't belong in Off Topic. An xbox is a console. Sure it's basically a computer but it's treated as a console. The mods stickied the Xbox360 thread in Off Topic. Not Peripherals. Not General Hardware. Not Video. Not Hot Deals. If the Xbox360 thread belongs in Off Topic, why doesn't a regular Xbox1 thread?
I doubt you will notice anything different between the MS pack and something else you could buy without spending a small fortune. Especially with the old XBOX, it will be just fine.
I have the MS HD AV pack (I think the second or newer revision) and I have no complaints whatsoever. Good quality cables and connectors, and choice between RCA or optical audio.
Typically I wouldn't recommend Monster because it is way over priced but for the XBox cable that is the one I used.
I said "OR" folks. "OR". I didnt say the Official Xbox thread IN Video or Peripherals. Just in Video or Peripherals.
OP had a bunch of places available that this could have fit better.
To answer ther previous question: NO. Off Topic is NOT for anything.
Is it set up for (get this) things that are OFF TOPIC. :Q
We have many hi-tech related sections already. Thats kind of what Anandtech is all about.
Too many folks think OT is the default. Probably because they're too lazy to put stuff where it belongs.
OT is not the default section. It where you make threads that dont belong anywhere else. We already have several places this could fit.
Can I assume I'm the only one who payed attention to the FAQ and Forum rules when joining?
Where did you get it? I heard they were solid but I haven't found them at BB, CC, or ebgames.
With my Xbox, I used the MS HD pack and had no issues. Actually, I've never even heard that it was subpar quality. *shrugs*
GameStop, for like $15.
Originally posted by: Crescent13
I have theese for my xbox. Combined with the monster optical cable and my home theater system games are awesome!
Can you hear the difference in the digital sound?
I hate when 1's become 0's and zero's become 1's due to crappy cabling :|
I have the MS HiDef AV pack, the newer one (they revised it at some point). I've compared it with my friend's Monster cable AV pack and I would definately say the MS pack is better.
OK, so why is the Xbox 360 topic stickied in this thread if this isn't the correct thread for Xbox related questions?
Thanks to everyone who's replied, looks like I'm just going to grab the MS one.
Thanks,
Ethan
How can you tell if the MS HiDef AV pack is the original version or the revision?
i am using the Madcatz cables from Best Buy (they run about $14) and have connectors for PS2 and old XBOX...work just fine on my Toshiba 57"...
the one from MS is the best.
the ones that are cheap arent really HD cable. they are component but it wont let you enable to higher resolution from xbox.
.... what are you talking about...
