- Jul 10, 2007
- 9,234
- 142
- 106
I did a search and came up with sort of similar topics, but nothing that was really what I'm looking for.
I have an HP W2207, and I want to hook up my 360 to it. This would be easy if it had an HDMI port but it doesn't. I've had it a while and it's one of the older ones.
I did a search and came up with this. It's more than I want to spend, but if I need to, I can. One problem with it is that I don't think I can plug that into my 2.1 speaker system. So, I searched on ebay and came up with this which I think would work. The only problem is I don't have my speakers here, they are at school, so I can't see what kind of cable I need.
Do you think that adapter would work?
I also looked into doing it my own way and came up with these:
joiner
adapter
and then just use the previous adapter for the audio.
Would this work? Because it would be a lot cheaper, but I would have to wait them to be delivered.
joiner
adapter
