That s all circular arguments to elude the point of said review..
Actualy what is obvious is that an A10 can be used for games
up to 1920/1080 while the 4600 can not, sometimes even
at lower res.
Whatever the point of the review, which itself said APUs have not kept up with increasingly demanding games:
"However, while the Trinity used to ensure playable frame rates in games at Full-HD and low visual quality settings, this is not so today. The hardware requirements of the recently released shooters have grown much more than the performance of AMDs A10 and A8 APUs. There are quite a lot of games now which dont run fast enough in Full-HD even on the Radeon HD 8670D core from AMDs A10 series APUs. The integrated graphics must make a step forward to become a truly full-featured modern gaming solution."
it doesnt change the fact that a low end cpu plus discrete is a much better solution for gaming or any graphically demanding app at a vary marginal (if any) increase in cost.
And yet his own benches contradict his sayings but i guess
that we re used with Anton Shilov s contradictions.
Out of 7 games he tested at 1080p 5 are perfectly playable
with the A10 , only Crysis and Metro are somewhat reluctants.
http://www.xbitlabs.com/articles/cpu/display/amd-richland-intel-haswell-gpu_5.html#sect0
If one wants to minimize heat and power consumption in a tiny box, something like a 6800k or 6700k makes sense. You won't need a dedicated GPU to play @720p or even @900p resolutions. 1080p is possible in a lot of games but arguing about BF3 or Bioshock Infinite at that resolution is expecting too much out of these APUs and quite honestly retarded. These are quite demanding titles and are meant to be played with high end discret cards. I play FIFA 2013, DIRT2, Diablo3, DOW2, etc @720p with a A8-3850
Ironicly looking at the review. You would have lower power consumption and better performance using an i5 4430+HD7750 than a 6800K.
what if the took the 8mb l3 cache from fx8xxx and stuffed it in the apu?
Not only that, you CANNOT use any slim SFF cases with Discrete cards.
Ironically you will pay $189 for the Core i5 4430 + $85 for the HD7750
Total = 189+85 = $274 when A10-6800K costs $149.
That would excude the 6800K as well, due to its high power draw.
I think you forgot performance somewhere. The 6800K would be disasterously slow compared in CPU.
ps: Also, if they used 2133MHz memory in every CPU, then the performance difference will be even higher using the official memory supported by each APU. Intel only officially supports up to 1600MHz memory. Only the A10-6800K officially supports 2133MHz.
So basically you are saying it is "retarded" to point out any data that disagrees with your point of view?
Even though I consider the A8 series the best value for money AMD APUs,the A10 series do have it uses,especially the A10 5700 and A10 6700 models. You could probably run a passively cooled box with one of them with the right case,running off a picoPSU.
You are also assuming that everyone is using 1920X1080 displays or even will not turn down some settings. Enthusiasts are all about(in Crysis nanosuit voice) maximum settings! maximum resolution! maximum gaming!
This is why we spend more on computer parts and change them more often than most other people. Its kind of our hobby too.
Most people will just turn down the settings.
Or get better performance by buying a discrete card and a low end cpu at very near the same price. It is humorous to see APU advocates continuing to claim you can game on an apu (which is true) but refusing to acknowledge you get much better performance from a low end card and a low end cpu. I an not advocating everyone get a high end gaming system, I am just advocating getting 2x the performance in gaming for very nearly the same price.
laptops should be closer, just like it was with Ivy vs Trinity...
but I agree, that DDR3 1600 (even the system ram they choose is 2133MHz lol) 7750 is really bad.... DDR5 model (reference model) is a lot faster...
Nothing new. GPU part is way overpowered for average facebook joe and too slow for most modern games at native display resolution. playing at 720p also ignores the fact that you loose image quality due to running on non-native display resolution.
the athlon 750k + discrete just makes a lot more sense. Here 750k + cheapest 7770 is only $30 more than a 6800k. And that without any rebates.
that is assuming that the native res isnt close to 720p. the a10-6800k makes more sense in many ways other than raw performance.
eg. it is better to buy a 6800k then upgrade. might not even need to upgrade, who knows maybe because the 6800k is adequate for blops2, league of legends, dota2, warframe, wow or cs:go and a bunch of other f2p / older titles in 1080p
