Chode Messiah
nice, are you using the stock cooler?
Originally posted by: arswihart
how loud is the stock cooler? Is it worth getting arctic coolers for these cards, or is it a minimal difference?
Hey all
I'm at core: 573mhz and mem 615mhz used Ati Tool to OC.
Originally posted by: bjc112
Originally posted by: KruptosAngelos
I have an x850XT PE, but it's pretty pointless to OC. It's the best card on the market, runs all games fine. No need for higher clocks.
What resolution do you play at?
The only difference between the AGP and PCI-E card is 20 mhz on the memory clock right?
I feel I could definitely use more power.
Originally posted by: Noid
Highest score (currently) at Futuremark is 5976 for an Athlon
Originally posted by: Ronin
Have both cards, but have only put the AGP version through it's paces. Currently, I'm running @ 590/620 solid with the stock HSF (haven't picked up a ATi 5 for it....yet, as there has been no need. The GPU doesn't go over 65C under load, and I still don't hear the fan. If I manually set the fan to run at 100%, the GPU doesn't go over 50C under load, but it's a noisy beast at that point).
I've used the artifact tester at those speeds as well. I ran it for 4 hours straight (while I was out running errands) and the time reflected for no artifacts when I was done was the exact amount of the time I'd spent gone, so I'm confident I'm at a 'no artifact' level of speed thus far.
Yes using the Stock cooler and my temps never go above 71c when playing WoW for a few hours. The cooling used is excellent, very quiet and seems to do its job well
