Sent out my Asus Sabertooth X79 for RMA. When I got it back I assembled everything exactly the way that I had it.
Here's the issue:
When booting it doesn't recognize all 32 GB of memory. But, when I go to CPU-Z it shows 32 GB but at Dual Channel.Also will not clock up to 1866 MHz it gives me like 1668 MHz instead. In the BIOS under tools it shows an abnormal SPD with 2 slots and sometimes when booting it sees only 8 GB and the rest are shown installed.
I've reseated my RAM several times and even reseated my CPU. There are no bent pins or TIM under the CPU. If I switch RAM slots then it still gives me the same readings.
I have matched voltages and latencies on the RAM both are 1.5V and 9-9-9-27 @ 1866 MHz.
Here's the issue:
