Did you try running 21x multi for the 4GHZ with HT on OC? Why 20x? I'm currently playing with my 930 atm , my current OCZ ram is giving me a headache as it won't run past 3.78Ghz with HT on with a 21x multi. Haven't tested with HT off yet. My higher quality Crucial memory is coming in the mail this Thursday.
Honestly, i've been lazy.
That & in my free time, i've been wanting to play Borderlands, etc, not spend time OCing. :hmm:
Oh, & 20x200 = nice even numbers :sneaky:
HT off will get you MUCH LOWER temps.
HT on = so much hotter.
I personally cannot see one bit of difference between 4 GHz HT on or 4.3 GHz HT off...either is more than fast enough for me.
Howdy n7! I found a retail CPU with this batch# that I may or may not buy... after an hour of looking around, I'd say your results are above average. Most of the newer 300* codes packed the last two months won't even do this without 1.4v or more.
Given your unique memory arrangement and low QPI voltage, I'm very curious if you've conducted any further testing with your chip? Done any testing for a max stable Uncore or higher memory speed? Enabling LLC makes the chip extremely hot so that certainly would be contributing...
I hate gambling, so I figured I'd do research this time around on batches and see if the result justified the time involved. 😀
There is a pretty detailed thread @ XS, & i believe a not bad one @ OCN, both of which have people listing their batches & OCs.
Don't think mine is very good compared to some i've seen, though if i had great cooling, i think i'd be doing a decent bit higher.
I'm presently using LLC1, which doesn't increase voltage under load...it pretty much just maintains it.
If i use no LLC, i get far too large drooping for my liking, which means i need a lot higher idle voltage.
As for uncore/RAM, that pissed me off quite a bit right off the bat w/ X58.
I basically could not get the 10x RAM multi working @ all.
Due to the [not] fun QPI/uncore/RAM speeds all being tied in to each other & the lowest QPI available being higher than it is on P55, i cannot seem to get my DDR3-2000 anywhere close to its stock speeds. D:
I'll have to fight with it more again sometime, but after trying various higher/lower QPI/uncore/RAM speeds combinations in which the majority kept ending in no POST, i gave up & settled on the 8x RAM multi till i feel like corrupting my OS someday. :\
