ofiraltarasy
Well i have to 4200+ But since everyone els says the 4400+ i would say go with the 4600+ an OC it
Originally posted by: stockriderman
cash does absolutely nothing except in games.Even there you only get 1-3fps. that's it!!!!!
not worth it. All of benchmarks say the same.
Originally posted by: Hacp
more like 3-5% if you look at anands articles comparing the 3800+ to the 4000+. Still not worth the extra money between the 3800+X2 and the 4200+ if you can clock to the same speeds.
Originally posted by: Kensai
The 4400+ should easily hit 2.6GHz, though sometimes it may not.
Originally posted by: McGeyser
You guys say cache does not matter for Workstation applications, such as 3D Studio Max, CAD and the Adobe lineup? Encoding does not benefit from cache? Where did you get that info?
The tests shown were not 3DStudio Max, nor Adobe Premiere nor Photoshop nor Maya. Have you tested these? How about Encoding times, you have seen Auto GK and Xvid? Don't worry 1M cache is fine but 2M makes a difference. However slight, in theory, more cache is less time spent fetching from Ram which is considerably slower than cache.
Originally posted by: Avalon
If you're going from an AXP 1600+, then whether you get an X2 3800+ or 4800+ won't matter. It will be such a step up from your old AXP that you wouldn't notice the difference between the two models, unless you have encoding projects that take many many hours alone. You could always overclock the 3800+ a couple hundred mhz to make up most of the difference. The extra cache from the 4800+ won't do much for you.
Originally posted by: absinthe
I've been drooling over the X2 4800 for some time. But now the 3800 has been released at a very attractive price and I'm wondering: Do I really need to spend $900 to $1000 just on a CPU?
