X2 steppings.
Originally posted by: Serch
Originally posted by: IsLNdbOi
Oh one more thing I just noticed. The HyperTransport Bus speed is 2GHz on the X2 3800+ and only 1GHz on the Opteron...
where did you see that? 1000 Ghz is the bus frecuency of Ht on both of them.
I guess you make a mistake and read the operating frecuency of the 3800 (that is, 2000 Mhz or 2.0 Ghz)
check
opteron: http://www.amd.com/us-en/Processors/Pro...nformation/0,,30_118_8796_9240,00.html
x2: http://www.newegg.com/Product/Product.asp?Item=N82E16819103562#DetailSpecs
c ya!
Ummm... It's on AMD's site:
X2
http://www.amdcompare.com/us-en/desktop/details.aspx?opn=ADA3800DAA5CD
Opteron
http://www.amdcompare.com/us%2Den/opteron/details.aspx?opn=OSA165CDBOX
Originally posted by: jasonlclei
E4 and E6??
When i check my msinfo32, it shows up as stepping 1........
OMG, i got it like less than 2 months ago too
I suggest using CPU-Z to see CPU information, it will show you ifits E4 or E6:
http://www.cpuid.com/
(look at the left menu, at the top you can find "software")
I guess E4 and E6 is shown in the "Revision" line.
Oh okay. Thanks.
Mine is stepping 1 E4. =)
