X2 Owners Out There.......
Unkno
1,659
well, i barely ever do encoding but i'm still planning on buying a X2 because, as i said earlier, would like to run some programs in the background that are very resource-heavy (firewalls, virus scans, downloads....) Resource-heavy programs also benefit X2 since one core would handle the game, the other core would handle all of the other programs running in the background of windows. GO to your task manager and see how many programs your already running. With X2, those programs would be running on the "second" core while you game on the "first" core. You won't notice any performace drop with X2.
X2's are actually not really expensive since it's two cores. It's almost the same price if you compare two 3200+ and one X2 3800+.
entropy1982
1,053
I actually have a question... how does your comp know that it shoudl use your other cpu for those proggies instead of the one you're playing hte game on.... i mean i understand if you had 2 things running it would be very simple.... but it's never that simple anymore ... everyone has more than 2 obviously
Unkno
1,659
windows xp is supposedly already programmed to handle 2 or more cores.
so, in other words, windows xp would figure it all out but you could always force different programs to use different cores in the task manager
aka1nas
4,335
Originally posted by: Griffinhart
So far, I've found that while a good single core chip is cheaper and a still a good choice for gaming/single threaded apps, my x2 has been a usefull test over all.
Of course the x2 shines for multitasking, but, There have been many times where it has made life easier. A good example is when you need to alt-tab out of a game like battlefield 2. This is something I do fairly frequently. On single core processors it's terribly slow. Even on P4's with HT it's not nearly as responsive as it is with an X2. At least it wasn't on my friends P4 vs my x2.
Certainly it's not required, but, once you experience and get used to it, you will not want to think about single core again.
I think you'll find that any dual core solution will multi task far better than any single core chip. HT or not.
Hehe, with my old dual Athlon setup I would have two or decently modern games running at once and alt-tab out of them when I got bored and play the other or browse the web instead. Think I had an RTS and something else both open for a whole week once.
entropy1982
1,053
How much do you guys think i will actually gain from getting the second core in terms of it taking over stuff like antivirus/spyware/defragmenting (would it actually help with that?) .... because i don't do heavy tasks like encoding movies and stuff
Duvie
16,215
I will put it in terms most of you will hopefully finally understand....
Gamers!!!!! Dont get the X2.....You wiull not take advantage of it...I dont want to have to continue to hear morons above saying how X2s are not worth the 3x the cost of getting an 3000+ and ocing it to 2.6ghz....The fact is I hate gaming...I dont do it....I think it is a waste of time....
But for me
speed testing at 2662mhz
http://home.comcast.net/~duvie23/x2-2662-11242-tmpgenccpu1.JPG
http://home.comcast.net/~duvie23/x2-2662-11242-tmpgenccpu2.JPG
2x faster then single cpu.....200% increase
http://home.comcast.net/~duvie23/cinebench2003-11242-2662.JPG
My best at 1.8ghz winchester at 2.66ghz was 376....87.2% increase...the other one was running 533ddr though and 7400's in sandra...maybe tweaking later will get that up more...
http://home.comcast.net/~duvie23/x2-2662-11242-povray37-bench-1cpu.JPG
http://home.comcast.net/~duvie23/x2-2662-11242-povray37-bench-xcpu.JPG
This newest beta version of Povray is fully multithreaded as seen in cpu task manager and subsequent 2x better score. This benchamrk doesn't draw picture but is the basic benchmark for comparison at their website.
http://home.comcast.net/~duvie23/x2-2662-11242-ADT2004-1CPU.JPG
http://home.comcast.net/~duvie23/x2-2662-11242-ADT2004-MULTI.JPG
As you can see the multi version of the test is multithreaded a bit. I had to take screen pic just at same time cause it wont post an end time. As you can see there is a 52+% gain...This was converting 11 frames to AVI 640x480...This will drastically cut down by 2 hour renderings for DVD quality 24fps clips...
So for all the gamers in this site (which at times sickens me)...there is more to life then worthless fantasy world to justify a purpose...
I run FH 2 instaces so my cpu hasn't had either core idle for 3 weeks...In the intel P-D world that may have been a dozen crashes later!!!
Griffinhart
1,130
I can't say I know the answer Entropy. My AV is fairly low profile and so is MS Anti-spyware. I don't use a software firewall, I just use a hardware one. I didn't notice any difference on that front really.
As for encoding movies and such, I can honestly say, before march, neither did I ever do it. Then I built a media center PC and now things are much different. There are several TV shows that I store until they come out on DVD so I convert them to a more disk friendly format like AVI or WMV. I convert several hours of video on a weekly basis.
In your case, I'd strongly consider how often you upgrade. If you upgrade now, when will your next upgrade be? If it's a year from now and you don't have need for multi-threading, then maybe take a pass at the x2. If, however, you plan to keep this machine for a few years, like many do, and aren't on a shoestring budget then I would recommend going to the X2. It will likely server you better for a longer period of time. Especially since games will start using the second core by the end of next year.
entropy1982
1,053
But for me
Actually "2x faster then single cpu.....200% increase" ... i highly recommend learning 5th grade english over again.... it's actually THAN ... there's a difference ... read up... i'm sure it's on the internet somewhere. Watch some more movies... that's not a waste of time at all... and it's not a fantasy world either.... idiot
entropy1982
1,053
Yea i totally see what you're saying ... thanks for being so helpful man =)
Duvie
16,215
But for me
I use mine for work and making money you dork....the movie encoding is a hobby but far more rewarding then playing a game...
Gamers only bring this site down in my opnion... They usually are the persons who are the biggest fanatic fanboys, and start about 80% of all the flame threads....ppl who actually build their computers for use tend to be more open and go where the performance is....
Bring it on biatch!!!! You are my new enemy...I will be looking for you!!!
Unkno
1,659
Entropy, the performace gains depends on the amount of resources/programs you have running. I myself would get a X2 because i like the fact that i could scan my computer, defrag, download while playing games or surfing the web. This means i wouldn't have to leave my computer online (good if your running a couple of loud fans in your bed room). With X2, you won't notice any "lag spikes" in game when a program suddenly needs to "do" something (update, run file, do it's job....) Since your already getting a 7800GTX (or maybe 6800GT) it would be better not cheap out on the cpu. It would be hard to sell the 3000+ because when dual cores are cheaper, it's most likely that most people would be looking at buying dual cores instead of single.
entropy1982
1,053
But for me
LOL.... that's hillarious "Bring it on biatch!!!! You are my new enemy...I will be looking for you!!!"
you make me laugh
by the way ... " far more rewarding then playing a game" ... you used the wrong THAN again... idiot (again)
I am in dental school and I assure you I will make more money than you will ever dream of in a couple of years, so don't talk to me about making money please.
Preferences aren't for you to judge... "ppl who actually build their computers for use tend to be more open " ... you seem like a very open minded person... idiot (again)
Unkno
1,659
btw, isn't that Need For Speed underground (icon/shortcut) in your first link to your desktop?
I thought NFS is a game
Duvie
16,215
But for me
you make me laugh
Whatever buddy!!! NOw you want to get all mighty cause you are going to dental school....hahaha....I make over 100k now, have an architecture degree I dont even use yet...I do side jobs as a surveyor and do custom CAD consulting for companies. Plan on starting an official business on the last one as well as a design company for custom homes....We can compare wallets later once you get off mommy and daddy's dollar....
I wasn't judging ppl I was merely expressing my opinion how this site is so dominated by gamers who only think a cpu worth is measured in gameplay.....It is part frustration from my days back on my p4c w/HT where ppl then though HT was worthless cause it didn't make their games run faster...It is just sickening ppl spend a thousand dollars to play games on a PC when they could seond 200-300 dollars and get a playstation...LOL!!!!
Duvie
16,215
My son plays it on my PC now and then, but hasn't since I got his rig set up upstairs.....I haven't reformatted since february and just haven't removed it....I converted my 6800 into a quadro card otherwise I wouldn't even have a higher end vid card....
entropy1982
1,053
Yes, it's very difficult to remove links from your desktop (you must REFORMAT!)... definitely need dual core for that
Duvie
16,215
I meant I have not cleaned off any software I am not using...I have enough HDD space so it is not a concern...I usually reformat every few months coinciding with hardware purchases but since I kept the same mobo for my X2 I haven't seen the need to mess with it.....
Big deal!!! I still dont game.....My only waste of time according to my wife is talking to you ppl....
entropy1982
1,053
lol ... You're a really funny guy .... and by the way you should really stop your son from being so useless.... playing all those games and stuff
Duvie
16,215
I think it is fine for a kid. He likes nascar and racing games. It is the older ppl gaming who need to grow up....
I am glad I amuse you....
entropy1982
1,053
That's good.... nascar... racing... movies... are all obviously much "better" than games... i'd love to see you tell people why movies is a better hobby than games are.
Btw look up some average salaries of dentists and multiply it by about 4 or 5 (new york city specialists) have a nice night =)
Duvie
16,215
Sorry I am not impressed!!! PLus NYC is a very expensive place to live. You need to make a heck of a lot more to afford things...LOL!!! I cant believe you are bragging up what you will be paid...What a p^ssy!!!! hahahahaha
As for movies being a hobby....I have used this hobby to convert my DV recording to DVD for easy playback for myself and relatives. I think archiving my childs life is a worthwhile activity. I also have made family events into interactive DVDs w/ menus. NOthing I plan to make money with, but probably could if I wanted.
I am done talking about this with you.....Go to bed now and stroke yourself think about the moeny you will make. I know I will be thinking about it with such envy!!!! :roll:
entropy1982
1,053
wow good job you have found a far superior hobby and all gameplayers should stop playing games immediately.... thank you for amusing me =) keep on doing things that you COULD BE making money on ...... lol
