Tempered81
- Jan 29, 2007
- 6,374
- 1
- 81
Originally posted by: jjmIII
How can you pass up this killer deal???
Hurry, rebate expires after tomorrow!
damn I need 120 of them
Hell, just pick up a good used 965 board here in FS/FT or even the IP35-E for ~$60 after rebate. OC that sucker and blow anything AMD has out of the water.Originally posted by: jaredpace
for 59 you can get an e2140, do a simple overclock, and be faster than anything amd makes.
QFT. Far better to get say an 8800GTS 320MB + E2xx0 vs. say an 8500GT + E8400Originally posted by: harpoon84
Cache is important for certain applications, but it's not a deal breaker. The biggest performance hits generally occur in gaming, but gaming is more GPU limited anyway (with certain exceptions). An E2140 @ 3GHz should be more then capable of powering a reasonably fast GPU like a HD3870 or 8800GT without bottlenecking, which is what matters.
That's too low. Performance starts dipping below BrisbaneOriginally posted by: n7
You can go even cheaper & get the Celeron E1200 if so needed
Originally posted by: hennethannun
As has been said above, AMD is currently only competitive if the following conditions are met:
1) Your budget for a processor is about $100 or less (maybe as high as $125)
2) You do not intend to overclock
OR
3) You already have an AM2 motherboard that you like and don't want to replace
If that describes your current situation, then consider both AMD and Intel and go with whichever system gives you a better mix of cost and features. If you only care about gaming then most $100 processors will be sufficient as long as you have a decent GPU and don't want to game on a 24 inch monitor at 1920*1200.
If you want to overclock at all then you should probably go with Intel.
Originally posted by: BlueAcolyte
Hmm... I notice Drebo pointed out that the E2XXX series only has 1MB of cache and so recommends the low-end athlon x2s... Which also have 1mb of cache.
The Intel chips are hurt worse by lower amount of cache than the AMD chips. One possible reason for that would be the IMC of the AMD chips.
