X2 game issue...Is it the same with ATI and NVIDIA?? How many problems are the P-Ds having???
Unkno
1,659
Originally posted by: lytalbayre
Run win xp pro. Haven't installed the AMD driver... will try tonight.
had problem with prince of persia sands of time. Manually setting affinity would not work. There was a task-assigner program that automatically sets affinity for certain programs, and this worked. No more problems.
Far cry bugged out last night. Manually setting the affinity worked.
try installing the amd driver, it might fix all your problems and you wouldn't need to use the task-assigner program thing.
Duvie
16,215
I have now tried nascar 2004, Need For Speed Underground 2 and 1, Flat out, all 3dmarks, airport tycoon 3, and they all are fine...
Xed
1,452
Update for my problem, tested out wow with my x800xt-pe and the 4400 and I had no troubles. Looks like its a nvidia issue for my rig anyway.
Side note - my 600w powerstream blew up last nite while just idle at desktop and took my 4400+ with it. (won't do anything in a different rig) Unhappy email inc to Ocz :)
Velk
734
I do not have the X2 driver installed, I do not set affinity for anything. I have no troubles with any games I have tried which include :
WoW, BF2, RTW, Doom3, farcry, Dom2, SEIV, Moo2, MoM, MK3, variety of emulated roms, wbc3, dawn of war, ee2, aow2, dungeon lords, sacred underworld, wesnoth, silent storm and spellforce.
I have not tried CS, HL2 or EQ.
Markfw
May 16, 2002
27,250
16,108
Unhappy email ? if that OCZ was under warranty, I would ask for a new 4400 or go to the BBB !!!
subzero813
111
Command & Conquer Generals + Zero Hour (hangs on start)
1) AthlonX2 4200+ on Abit AN8-Ultra w/Corsair 1GB PC3200 and Windows XP Pro x64
2) no X2 driver
3) latest nvidia driver on GeForce 6600GT
4) game is patched
5) latest nvidia forceware drivers
6) can't get far enough to mess with affinity, and RunFirst doesn't help.
LT4CAMSS
122
Originally posted by: fatty4ksu
Bottom line....this is utterly embarrassing for AMD.
I admit this is a problem...but I'm sure w/ some pestering it will be corrected. Also, there is this temporary fix which has worked for many people. I'm also sure people are working on patches for this as we speak. A wide-spread issue such as this will not go unnoticed most of the time.
DarkSpeed
4
Hey dude's, I'm new here and I've got a problem that I've been trying to solve since I brought the 4600+. I've been everwhere looking for a fix to this problem. No such luck for 2 days!
Here are all the things I've come across and found out, before I found this place. lol
I installed America'sArmy ( AA ) and when I went to run the game, I got a Credital Error right away saying this after I clicked on the AA.exe
No Label
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD Unknown processor @ 6305 MHz with 1023MB RAM
Video: RADEON X800 XT (6561)
Negative delta time!
History: UGameEngine::Tick <- UpdateWorld <- MainLoop
yeah thats the full error message I get from AA.. Mind you the clock speed seems to differ from the 6305 Mhz to -5678 Mhz or at one stage 2345 Mhz.
I don't understand how the clockspeed can be in the minus tho?
What I've found out sofar from doing a hell of alot of searching..
Negative Delta Time is a possible issue with the unreal engine when having 2 processors or a dual core.
Some links to ut2004 threads with the same issue, ut2004 is a different game but its the same engine so the problem's cause is the same.
http://www.ataricommunity.com/forum...threadid=487077 <--- Read This one
http://www.ataricommunity.com/forum...threadid=381174
They both have possible ways to fix it though.
So there saying it's any game that use's the UNREAL Engine that has a problem deteching the DuleCore.
Also I had a major problem afterwards when trying to play BF2. I had BF2 installed 1st and was running smooth as for a day.. It was only lastnight that I decided to install AA to make sure it was goiing to run ok. Then I get the CE, understandable.. But when I went back to BF2, I join multi player and as soon as I do. Sound starts messing around with squilling and what not..
Then the screen goes black, then she reboot's.. I get a message at the start of windows/after its loaded up saying, Your system has recoverd from a cridital error. Problem caused by device driver or new hardware..
I didn't get this problem until I installed AA, and yes I uninstalled AA to see if it would fix the problem as it was the very last thing I installed.. But no go there, so I had nochoice but to do a system recovery in the end and now everythings back to normal and BF2 is working again.. This one has me stumped!!
Here's some of the dxdiag information
System Information
Time of this report: 8/24/2005, 00:01:59
Machine name: DARKSPEED
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 08/02/05 09:44:56 Ver: 08.00.09
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 1024MB RAM
Page File: 223MB used, 2236MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
CPU: AMD64 X2 4600+ @ 2.4Ghz x2 skt 939
Mojo: ASUS A8V skt 939 ( 2004/5 Model ) - BIOS updated to work with DULECORE CPU
BIOS Vers: A8V BIOS 0211 2005/08/16update
GFX: PowerColor X800XT 256Mb AGP @ 520Mhz - Overclocked
RAM: x2 512Mb Corsiar XMS DDR400 in 128bit Dule Channel mode
PSU: Antec True Power/True Controll @ 550Watts
Sound: SoundBlaster Audigy2 ZS
Well that's about it.. New windows installation, new/lates chipset drivers ect ect.. Just no AA.
Also what's this program you's are going on about, I tried the ROPE thing. But couln't figure out how to use the thing.. Also it was made in 2002?
I really hope someone here can help me on this as it's starting to make me go nuts.. LOL
subzero813
111
that is odd because my friend's computer installed/ran America's Army fine without anything, he had problems with other stuff.
BlingBlingArsch
1,249
lol, iam sry.
somebody should get to the bottom of that...how can it blow in idle mode, weird. that antec bunch owes u a dualcore....
and change ya signature ;)
Duvie
16,215
No Label
System Information
Memory: 1024MB RAM
Ok....Like I tell everyone install the AMD X2 cpu driver I linked above...The first one sounds like a timer issue and right up the alley of whatg the driver fixes...
The 2nd one sound like possible corruption of the direct X sound drivers perhaps...I see that you are not OCing but perhaps your memory timings are a bit aggressive. If it does not happpen again at this speed eventually then it is not the memory thing...just throwing out ideas cause the last one is a bit odd...
Markfw
May 16, 2002
27,250
16,108
As Duvie and I have repeatedly said INSTALL THE X2 DRIVER, IT PERMANENTLY FIXES THE PROBLEM FOR ALL GAMES !!!!!!
LT4CAMSS
122
I didn't say I had the problem buddy. I said that this is a problem that can be corrected; that basically it's not worth all the fuss and exaggeration of it being such a big problem. Why do I say so? B/C there are people who actually have done most of the updates and still experience some issues (WHICH ARE BEING TAKEN CARE OF BY UPDATES FROM THE GAME MAKER). I didn't sh*t on AMD...those were fatty4ksu's words.
Markfw
May 16, 2002
27,250
16,108
OK, when you buy a video card, you install a driver. When you buy a modem, you install a driver. by your own words "I admit this is a problem" you say it is a problem, but I ask why, when all you have to do is install the companies driver for the hardware ? That was and IS my contenion.
chinkgai
3,904
no, not all games. quite a few people reported it didnt work for them.
worked for me tho, but i only play one game ^^
Markfw
May 16, 2002
27,250
16,108
OK, I have been following this thread. Which game didn;t it work for ? (except the people that didn;t install the driver)
chinkgai
3,904
x2 patch and the launcher prog haven't helped in WoW. If nvidia's beta drivers don't fix it I'll just have to go back to my 3700 and use the 4400 as a work box =(
he's just one, i've read others...but im not gona bother to look for them. even tho others have WoW working, installing the patch alone might not be the fix, especially for all games, is my point. thats it.
Markfw
May 16, 2002
27,250
16,108
Well, I will go back and look. I guess my point is, if one person gets wow to work by installing the driver than it must be something the other person is doing wrong. But lets see what develops.
Thor86
7,888
7
1) X2 3800 @ 2.5Ghz
2) X2 driver is installed
3) ATI driver used (Catalyst 5.8 no CCC)
4) Latest game patches
5) 6.66 Nforce chipset drivers
6) whether changing affnity for process helps or not... (Haven't tried it yet.)
BF2 works no problems, and even before updating to the 6.66 drivers.
Diablo2 loads and plays, but doesn't exit cleanly, as it freezes the system when exiting the game.
CS:Source still doesn't load up. Will have to try the changing of affinity process.
All I have to say is I am pretty disappointed that X2s have this bug.
Markfw
May 16, 2002
27,250
16,108
Originally posted by: Thor86
1) X2 3800 @ 2.5Ghz
Before you judge, you have to try at stock speed.....
LT4CAMSS
122
Ok, this is silly. You know what I'm really trying to say (I think) Mark. Problems are not always permanent kinds. There are temporary ones and in that respect, yes, it is a "problem." Fixible by downloading the driver? Almost all the time. Some people are still having problems though. Is is their error? I don't really know to be honest. I do know this so far though. Some people have their system @ stock speeds, all the updates installed, etc., and still this problem. Are they the idiots? Maybe. But that's why there's this thread. For those special "unfixable" situations, I think we'll either get to the root of the problem or just find out that the person was doing something wrong. I'm not disagreeing with you though.
subzero813
111
btw, my friend installed the X2 driver, and it let C&C generals actually load. but then within minutes of entering a game, his computer just reboots. his memory timings are 2.5-3-3-8 and are exactly according to SPD.
