Originally posted by: letdown427
hey, thanks for trying it out! it didn't work? i think that's probably game specific, erm, what game is it?
if you try it with sa y notepad, it definately works lol, and i've launched many a game with nit ehre.
The long bar is for the address, no speech marks, no bracket at the end (that may cause it?)
then the .exe goes in the bottom, again, no speech marks etc. so it'd be
c:\windows\system32
notepad.exe
in the two boxes. that should definately work, as all the code really does is take the directoy from the first box and launches it from that folder (as this is necessary in some games, and then basically sends launches SA [what you typed] 1 to launch on cpu 2.
either way, i'd be more than happy to try and solve that, so any details would be helpful in helping me fix it. hopefully some more people will try it now.
that's weird. if it's exited the program, that means that it has gone through and done what it is meant to do, i.e launch the program,
you may need the visual basic runtime libraries? its a .dll, that might be why. dno, seems odd, as it works on my XP pc at work (i presume it's XP you're on).
i'll find a link to the necessary .dll and edit this post. sorry about that :S
http://www.softwarepatch.com/windows/vbrun6.html
Yeah, there's some info a bout it on the site, they're needed to run apps written in vb6, i.e this one. sorry lol, forgot about that.
Originally posted by: biostud
even though the process is manual, do you need to set affinity every time you reboot or can you save the settings?
Bump for an update. I've added the option to control which CPUs get assigned to what, so if say your core 1 can clock higher than core 2, you can run the game on core 1 and assign windows etc to core 2. It'll remember these changes too, so once it's set u, it's setup.
It'll also work with Dual Core HT CPUs aswell, you can choose which cores get what etc. I'll PM instructions on how to use it if anyone ever decides they want it, which seems unlikely at the moment. Hopefully SynthDude will host the newer version.
Got your email this morning...uploaded the new file, URL is the same as before![]()
Sorry I haven't been able to look at the program much lately, I've been pretty busy with school and other stuff...I'll give the latest version a spin this weekend![]()
