Refractoryman
What is a safe temp range for a X2 4800? What temps are you getting? I get the following at idle from Everest. Rig consist of;
A8V mob
X2 4800 (No oc, stock heat sink and fan, (due to error on installation I had to clean and re-apply thermal compound (Artic Silver 5)
2gb ram
antec p180 case (Top fan blowing in, HDD fan at bottom, front fan middle of case, rear fan blowing out)
ATI AIW X800 XT
Field Value
Sensor Properties
Sensor Type Winbond W83627THF (ISA 290h)
GPU Sensor Type National LM63 (ATI-I2C 4Ch)
Motherboard Name Asus A8V Series
Chassis Intrusion Detected No
Temperatures
Motherboard 27 °C (81 °F)
CPU 41 °C (106 °F)
CPU #1 / Core #1 40 °C (104 °F)
CPU #1 / Core #2 42 °C (108 °F)
GPU 46 °C (115 °F)
GPU Ambient 46 °C (115 °F)
Maxtor 7L250R0 33 °C (91 °F)
Cooling Fans
CPU 2974 RPM
Chassis 1140 RPM
Power Supply 1068 RPM
Voltage Values
CPU Core 1.36 V
+3.3 V 3.28 V
+5 V 4.92 V
+12 V 12.16 V
A8V mob
2gb ram
ATI AIW X800 XT
Field Value
Sensor Properties
Temperatures
CPU 41 °C (106 °F)
GPU 46 °C (115 °F)
Cooling Fans
CPU 2974 RPM
Chassis 1140 RPM
Voltage Values
CPU Core 1.36 V
+3.3 V 3.28 V
+5 V 4.92 V
+12 V 12.16 V
