apoppin
Originally posted by: zodder
Are you using the latest Catalyst drivers (7.xx)? If so, install the 6.12 drivers instead. It gets rid of the flickering screen and lets you overclock your card.my *Sapphire* x1950p/512 works *fine* with exactly 18a on the 12v rail ... but i can't O/C at allI had the same problem, and the 6.12 drivers took care of it and my card is currently running 621/749.
i had 6.12 ... i can O/C with the very latest Cats ... also ... the OC renders my rig *unstable*
if i also try to run with my CPU OC'd to 3.31 Ghz it is also unstable ... so i backed doen my 2.80c to 3.2Ghz --almost no performance difference and it is *stable*]
it really *needs* 30a on the 12v rail ... and i will upgrade my PS when i can afford a 1,000 watter for my next xfire rig
-- but use it in my rig now, why not?
