Is a PSU with 28a on the 12 volt rail going to be enough for this card?
Here is my supply Athena Power AP-P4ATX50F12 ATX12V 500W Power Supply
Originally posted by: Journer
is there anywhere in the US where you can buy the HIS 512mb w/ ICEQ cooling? would there be any problems with warranty if i live in US but buy from UK?
also, how long is this card? ive got a XFX 6800GT in my case and it is a close fit...i got about a 1/2" from the end of the card to the case. so how much longer/shorter is this than the 6800gt
also as far as power supplies...this is what ive got:
a64 4000+, 4 case fans...all stock...all 80mm...one CPU fan (80mm i believe) high flow, 1x 10k raptor 74gb, 1x dvd-rw, 2x 20mm fans for the cooling bay for HDD, running a g15 keyboard and ipaw dock from USB...thats about it i think
right now ive got the 500wt PSU that came with the case...i forget the brand...but ive also got a 480wt enermax that is pretty nice...i cant think of the model# and i'm too lazy to look, lol
edit:
also is the reboot problem only with saphires? thanks
Originally posted by: AgonxOC
I really would like to know if it is worth the time waiting for the 1950XT? I want a 512MB card as I do alot of high res, high quality gaming. Any word on the 1950XT and if it is going to be 512 MB.
Alex
Originally posted by: ronach
The warm re-boot problem is discussed in detail over on the Sapphiretech forums. http://www.sapphiretech.com/en/forums/showthread.php?t=10167 . Hopefully those here don't have this malady, or better yet, were able to circumvent it in some way and share this info with others. There you have it.
Alex
Originally posted by: apoppin
ouch ... looks like only Sapphire ... which is the only brand - so far - with 512MB vRAM
i haven't seen anything like it ... cold, warm, hot ... starts up completely normally with no delay whatsoever or any issues at all
i wonder if these are all the *same batch* --mine would probably be the 2nd.
but, thanks for the head's up!
i know i have 2 years warranty ... so far so good![]()
Alex
Originally posted by: honestjohn
Ok, it's now across the pond. NewEgg has the HIS X1950 Pro 512MB card up....for $339..which is more expensive than getting it shipped from the UK at the moment. Also, the description is wrong, but the part number is correct. They have the 256MB version listed for $279.
http://www.newegg.com/Product/Product.asp?Item=N82E16814161069
And another X1950 Pro has made it across the pond, Gecube 256MB - in-stock - at NewEgg for $239
http://www.newegg.com/Product/Product.asp?Item=N82E16814241041
Think I'm done with these posts now, it looks like the X1950 Pros are going to be everywhere soon.
$339.99
HIS Hightech H195PRQT512DDAN-R Radeon X1950PRO 256MB 256-bit GDDR3 AGP 4X/8X IceQ3 Turbo HDCP Video Card - Retail
Memory Clock 1480MHz
Memory Size 256MB
Memory Interface 256-bit
Memory Type GDDR3
what is HIS's manufacturer warrenty?
$339.99
Memory Size 256MB
Memory Type GDDR3
where do you see 512MB?
it's awfully expensive for a 256MB card
:Q
Originally posted by: zcubed
eh...just found my first huge error...dunno if its game related or the card...was playing Black and White 2:Battle of the Gods and the game was running perfectly with no artifacts at full settings then the gmae suddenly just shut off. no error report or anything. just turned off. and went to my desktop like i exited the game. i tried lowering the resolution to see if maybe i was over-stressing the card and the game did the exact same thing. in both instances the card never went over 70C so its not overheating. maybe its a power issue? but wouldnt there be an error report if there was? the way the game is crashing i have no idea whts going on. no other game has done this. not even FEAR.
black and white 2:BOTG never got a patch. the original game got 3 which i have installed. i havent tried playing the original yet will try that and get back to u. its a real shame that a card that could run the game so smoothly wouldnt be supported. as far as the card running real warm, it does do that but thats mainly the ****** coolers fault. it idles at 49~50 which is fine for me and doesnt go above 75 which is ok for the chip. what is this reboot problem ppl r talking about?
