X1900XTX has IQ Problems
Munky
9,372
Originally posted by: apoppin
[ATi]explained that this shader is different than the one used on either the the X1800 or the GeForce cards because it "employs both Fetch4 and 24-bit DST" in order to best take advantage of the X1900's capabilities.
Fetch 4? . . . isn't that part of ATi's "workaround" for VTF?
No, it's not. It basically means more efficient operation on single-channel textures.
flexy
8,464
155
Originally posted by: mooncancook
I can't tell the difference between those 2 images. I think i need to have my eyes checked by an optometrist
there is a SMALL diff on the FLOOR...the X100 shows something like dithering - but it's a driver (shader-compiler) issue - SO.,,,their drivers need a small fix....big deal :)
akugami
6,210
2,552
This texture dithering issue seems to be on par with the badly rendered shadows on the gun in Farcry. Almost a non-issue. Now, I'm not saying it shouldn't be fixed...but unlike shimmering or the purported gun flickering issue in BF2 some of you are reporting, it doesn't affect gameplay and you probably won't notice it during gameplay. I'm more worried about the flickering and shimmering reports...ATI needs to get it's 6.2 drivers out and hopefully squash most of the bugs soon.
