X1900XT - Driver Problems solved?
lavaheadache
6,893
14
hmmm, not sure which driver problems you are talking about. All I can tell you is that I dont have any.
sodcha0s
1,116
??? What problems are you referring to? I went from an x800xt pe to an x1900xtx with no problems. If you're talking about going from an nvidia card to an ati card just uninstall your video drivers, reboot into safe mode and run driver cleaner to remove all nividia drivers from the system. Shut down, swap cards and all should be well.
BFG10K
22,709
3,003
ATi have far less problems than nVidia I can tell you that, especially in games and settings that aren't actively benchmarked.
Capt Caveman
34,543
651
I went from a 7800GTX 512 to X800XL to X1900XTX and never had to reformat/reinstall windows.
Elfear
7,164
821
No problems with drivers here. What problems are you refering to?
CP5670
5,660
762
I don't think there should be any stability problems in most cases. That thread is somewhat old and some of those game incompatibilies have been fixed since then.
That being said, it seems that the latest 6.3 Catalyst set has broken something in one older game that I play a lot and causes BSODs when you start it up. I was about to buy an X1900 XT last week until this came up.
