I just received my new card yesterday, X1800XT 256MB. I was looking to buy X1900XT for a very long time, but my monitor broke down and I had to buy a new monitor also. So my maximum budget for the card was 350?.
The X1900XT was 160? more expensive, so it wasn't a realistic choice for me (not enough money), so I narrowed it between X1800XT (that I have now) and 7900GT. 7900GT Isn't widely available available here at the moment and basic models (not the overclocked ones) are as expensive as the X1800XT is. And both have 256MB of memory. so I went with X1800XT.
Image quality seems to be good, I haven't been able to test it a lot with games yet, but first run with stock settings and with 2GB of RAM And A64 3500+@2.5GHz gave me around 8900 points in 3DMark05. I guess that is close to normal result with my setup?
Now there are few questions that are bugging my mind: Does X1800XT use some kind of a different 2D/3D -modes with frequencies and core/memory voltages? I've read from several threads here that X1800 -series have built in voltage control, but how do I use it? does it increase voltages for example when using ATIs own Overdrive?
And is ATI Tools the best utility for tweaking the cards overclocking, fan speed and other options? I had problems even during using Ati own command center and its overdrive (which crashed immediately). I installed ATI Tools, but I don't know the safe limits/steps to try out with the card, or what are the safe GPU core and memory voltages using stock cooling? Any advice to that would be appreciated.
