X-Qpack clone $39 shipped
WhoBeDaPlaya
7,415
404
Nice deal for a nice case! The best part of it is that it has a rear 120mm, supports full-height cards and uses a full size ATX PSU.
Vincent
I received mine yesterday and set up a new system. It's not perfect, but I'm pretty happy with it.
It has touch-sensitive power and reset switches. I wonder about their long-term reliability. I would be more comfortable with mechanical switches.
I couldn't fit my OCZ 400W power supply in the case because the PS is too deep. Fortunately I had an Antec Earthwatts 500 that fit.
I had to modify one of the front-panel USB connectors to be able to plug all of them into the 3 USB connectors on my motherboard.
My setup (Athlon 64 X2 5050e/Gigabyte GA-MA785GM-US2H) runs a little hotter than I'm used to. It looks like there's space for a front 80mm fan.
The included case fan is noisy (58.3CFM/27dBA).
The optical drive cover interferes with my DVDRW drive tray. The cover prevents the tray from opening and closing sometimes. The work-around is to hold the cover open.
I initially had trouble with the motherboard power cable adapter. In the end I had to attach it to the PS connector first and then attach it to the motherboard.
The USB/2.5" PATA drive portable enclosure is not particularly useful to me.
Binky
4
Even better is that it doesn't come with the POS power supply in the Qpack model (it comes w/o power supply). The Qpack power supply is annoyingly loud.
Pardus
8,197
21
Was considering this case or the COOLER MASTER Elite 360 which is much bigger, my concern with this case, is what power suppy, burrner, gpu will fit and will the extra power supply cables be a problem to tuck away.
The QPack case would be great if they didn't include the crappy power supply.
Can anyone tell me if these parts will fit in the case:
GIGABYTE GA-G31M-ES2L
CORSAIR CMPSU-400CX 400W
Intel Pentium E6300 w/stock cpu fan
LITE-ON CD/DVD Burner iHAS124-04
ECS NSG210C-512QS-H GeForce 210
