The Pentium Guy
- Jan 15, 2005
- 4,327
- 1
- 0
Installing a heatsink while sleeping (sleepwalking) is never a good idea. You made an excellent decision by doing it in the morning.
Originally posted by: HAM617
Heat that high with functioning heatsink could also be overclocking. Go into the bios and make sure you are running at stock speeds. Also download everest which will report what speed your processor is running at. I had an issue once that turned out to be my cpu overclocking without me knowing. IF it is high set the bios to default and then change anything else you had different.
The Socket 754 version of the 3000+ runs at 2 Ghz
The Socket 939 version runs at 1.8Ghz
Also verify you are running the same voltage. These vary depending on the model number of the 3000+ which you can also get from everest.
The amd link is here
http://www.amdcompare.com/us-en/desktop/Default.aspx
The link to get everest home edition sharware is here
http://www.lavalys.com/
Good Luck
Originally posted by: alexXx
you will lower your temperature by 13 degrees if you get your case temperature down to 30C. 43C is a sure sign that your case just has no airflow. Asside from that, use the default hsf. MAKE SURE you read the instructions for it and know you are putting it on correctly.
I just spent the last hour and some cleaning all the dust out of my fans, trying up / tying down my wires and folding my ide cables. My case temps havent changed at all =/. I'm thinking about just investing in a new case as soon as my dad decides to actually let me spend my money --"
Oh btw mechBgon, I went ahead and redid the headsink again just to check. The side that was harder to put on was not the side it should be on, it would look like .. dont remember which one it was, but where the step was on the wrong side. Because how I said before both sides were stepped, the side needing more force was a smaller step and thus didnt work.
