ArchAngel777
- Dec 24, 2000
- 5,223
- 61
- 91
Originally posted by: TGS
Originally posted by: ArchAngel777
The shield isn't very good at L60, that is for sure. 960 HP isn't much :-/ It would be nice if +Healing or +Damage & Healing work for that shield, that is for sure. But being that instant spells only use like 43% of the +damage or healing, it will not go far. I am running with about +250 spell damage right now and according to my math, if those shield changes were implemented, it would be like 1075 HP or so, instead of the 960? or so that it is.
Preists don't really do any CC when deal with PVP. You really cannot count mind control, because it is broken very easily, and when someone hits you... Not to mention, you just sit there like a dummy in the other characters mind![]()
Yes, but at least it should scale like epic weapons. I've been hearing a lot about how spells aren't scaling like epic weapons are giving the edge to the melee crowd. If only there were some epic spell drops.
Originally posted by: cKGunslinger
Wow - I can't believe so many people have never tried BGs. Battle Grounds are what keep me paying $15/month. I don't do them all the time, but they make for a nice break every once in while from PvE action, questing, and grinding.
Communication and teamwork is, obviously, the key to sucess. I've been in many, many Alliance PuGs that are destined to fail, and they typically do. The best BG action (I like AB) is had when you join as a group with a few guild-mates. You don't have to fill the whole team, but 4-5 is plenty to turn the tides of battle, if others are willing to listen a bit.
Yeah, I've been grinding out out for 40 so I can go in full face melt mode. I have around 160 HK from solo and some duo killing. I'm fairly good at taking down those around my levels but in a group environment I have yet to get in real big fights. Though I'm sure to disappoint a few people as I'm a master at ninja kills. I have to be to get a near constant spirit tap proc. :laugh:
I'm probably going to run my first real BG tonight, and experience the pain of being target numero uno. Oh I'm going to be packing a lot of mithril frags tonight, boys and girls... I know in the patch notes they mentioned mind control helms get diminishing returns. I'm curious on this, as does this mean you can carry around multiple helms?
Good luck with your priest! They are a lot of fun... I have to warn you though, ShadowForm in PVP isn't all it is cracked up to be. You still take the same amount of magic damage and not being able to cast renew on your buddies, or a quick flash heal can be a bad thing. The global cooldown for leaving ShadowForm is the speed of your wand, which seems like forever in a PVP fight.
You are right, melee weapons keep getting an upgrade while spells are just sitting still. Right now the biggest fear I have is a Warrior decked out in good gear... I basically cannot beat them, or get away for that matter. Rogues are pretty mean too, but I can get away from them usually.
