Would you rather look real strong/buff and be weak OR look rather weak and scrawny but be real strong?
alkemyst
83,769
19
Originally posted by: apoppin
Originally posted by: alkemyst
5'6" and 160lbs doesn't make you chubby necessarily.
He is more than likely built like a tank....unless of course you think because you aren't no one else can be.
When I was 190lbs people said I must be fat too until they saw me (5'10.5")...I like to stay around 175-180 though with a little bodyfat on me still, at the 190lb mark with a little bodyfat I'd have been more like 210lbs probably and still not chubby.
Sure it does unless you are completely musclebound . . . 5'6" is pretty short - you cant compare since you are 4-1/2" taller . . . :p
And did you believe the 6% bf also?
:) I figured the 6% the last time I was at the doc was tongue in cheek.
My friend was about 5'6" and around 160lbs and we was a champ wrestler (H/S and college stuff, not WWF). Hardly musclebound either as he you really can't be as a 'real' wrestler.
He was also the guy that got me to realize my true potential....which I let go this past year in a cocktail of beer and stress (I am about 185 now...was 175 in shape so however much muscle you loose in a year + weight gain). I *used* to be the guy that took off his shirt and people talked about it...now I am the guy that takes off his shirt and people probably hurt themselves running for cover :) Luckily I shed weight fast, 3 months I can be close to an animal again. me shall crush! crush crush crush :)
Geekbabe
Moderator Emeritus<br>Elite Member
Oct 16, 1999
32,229
2,539
www.theshoppinqueen.com
I'm actually starting to get a bit of muscle in my arms and shoulders,I've been quietly borrowing my dude's hand weights and using them,now if only my ab's would come along,lol,I hate leg lifts:D
apoppin
34,890
alienbabeltech.com
Leg lifts? . . . aren't crunches the ab exercise?
whaleskinrug
1,114
Naw, you want to do a variety. Crunches with weights are good but leg lifts are great, too, as long as you have proper positioning. And there are many other ways to hit the abs.
keystroker
653
everyone says i'm stronger than i look. i have nice muscle tone, i used to do about 80 pushups in 2min and 90 situps in 2min. I'm in the army reserves and i keep in good physical condition so I can pass the P.T. tests. I rather look strong and be stong.
apoppin
34,890
alienbabeltech.com
If they are shooting at me, I'd rather be as small a target as possible (and strong and fast). ;)
:D
Good luck with your tests.
As to the leg lifts being useful to condition the abs . . . thanks (I guess).
:D
LAUST
8,957
typo.. 16% I'm not an olympic athlete just healthy
apoppin
34,890
alienbabeltech.com
ah, 16% . . . that is more like reality . . .
are you done with growin' taller 'cause over 160 might not be 'healthy'?
:D
alkemyst
83,769
19
Crunches work upper abs which more people can get easier....leg lifts work the lower abs....
In most women's cases the 'pooch'/pot belly ;).
However spot reduction is impossible....and unfortunately for most people abs are the first to get the extra weight and last to remove it.
Geekbabe
Oct 16, 1999
32,229
2,539
my "pooch" was caused by repeat abdominal surgeries and I am also losing weight along with exercising.
