It's gotten to a point where I'm about to get a quote from a manufacturer of cases for a case that has the following...
1) It must be made of steel. that's right, steel.
2) The case would be truly full sized without cheating by making a tall case skinny. It would be a full 12 inches wide so it could come standard with two big water radiators in the rear of the unit stacked one on top of the next so it can do a double loop with one loop servicing the CPU and chipset and the other one servicing the video cards.
3) It would have a no B.S. water pump mounted neatly away and shock mounted so the vibration was kept to a minimum.
4) The front, bottom to 20 inches up the front of the case would have 120 mm fans, a total of 8 of them that all turned nice and slow. The case would be almost 24 inches tall as a result. The fans would push air over all the hard drive units that also would have rubberized shock mountings to reduce the noise they made. In front of all these fans would be a single, removable filter that you could blow out and re-install keeping the unit clean and neat. There would only be room oddly enough up top for two optical drives, but what someone needs with more than two I have no idea why!
5) It would be available in any factory color an old model T was available in directly from Ford in 1924!
6) It would have no stupid lights or see through panels. At the most, to compliment the black case, you could add a bit of chrome trim, but I'd even skip that one. It would also be sealed air tight in all areas except where air was intended to flow in or out of. This would cut down substantially on noise.
7) Instead of waisting an entire optical drive bay for fan controls, it would have a fan control setup resessed into the top, front area of the unit with simply and straight forward controls for the fans and the pump to increase or decrease the speeds of the fans ans a whole only and another speed control for the water pump. It would have the case temperature sensor mounted at the top of the case where it belongs.
8) Instead of having to buy increasingly powerful power supplies just for the sake of the 12 volt needs, it would have it's own 12 volt power supply mounted above the hard drive rack that would be relayed so that when you hit the start button, it would drive all your cooling fans including hookups for the fans on your mommaboard if you wished to opt that way and the pump. There would be an infared fault alarm system that would detect if the pump or fans did not run and automatically shut the PC down if that happens and give you in the fan control display the reason for the shutdown in plain language instead of some cryptic code.
9) Between both the case fans and the pump being run by it's own power supply that would not need to cost as much as a standard PC power supply due to pumps and fans not needing prefect power, it would make it so most water cooling folks could get away with using a power supply 25-30% smaller than the monsters they are now considering for their next build.
10) It would have a bit of ducting so some of the air would be directed behind the mommaboard.
11) I finger the production costs of a unit like that with high quality fans already included along with a no nonsense pump, relay and fan and pump speed control setup would cost about $160.00 U.S. That if far more expensive a production cost than the cases they sell you for $300.00 U.S now, so I doubt we'd ever see anyone make a case like that. I could make a go of it as long as I got a thousand preorders at $250.00 a piece, and that would be a lower 48 State delivered price, but I think the snowball stands a better chance in hell than I ever do of getting that sort of response.
Ok guys, go ahead and tell me it's all nonsense! :disgust:
