Capt Caveman
External battery packs if you need to recharge. And the non-removable battery on my Nexus 5 is easy to replace.
I'll end up buying whatever phone is available when I need one. That will be whatever trendy piece of crap kids have been convinced is cool at that moment.
At the end of the day, aside from making calls, a smart phones real utility is about the same as a pencil, and trending down.
Meh. My lumia 635 was $50. Has a removable battery and storage expansion via SD slot. It makes calls as good as any phone 10x it's price, answers emails, texts and takes basic pictures. You can browse the web and get most basic apps. Battery life is excellent too. Trendy not need apply.
lol, okAt the end of the day, aside from making calls, a smart phones real utility is about the same as a pencil, and trending down.
Yeah. Google Fi was recently announced and only works with the Nexus 6 so far. You can't just update other phones because the IMEI has to be registered/allowed on Sprint, Verizon, AT&T, T-Mobile, etc. If I understand it correctly, it's like a VoIP cellular service that is hopping between whichever carrier has the strongest signal and really only using them for data services, which is why the phone service works seamlessly over WiFi when it can't access any of those cellular networks.I had to look that one up. Never heard of that service before.
That's good to know.
Agreed, ease of swap would be nice.
And thickness of the phone matters very little to me.
FUNCTION over form.
For a portable device, thickness matter a lot.
But I'm wondering what type of person doesn't know how to use a screwdriver once every three years to replace a battery pack.
Ditto. I pretty much agree with OP, the trend towards non replaceable batteries is to promote planned obsolescence. The phone manufacturers are following the same business model as the Big Three automakers of the fifties and sixties-get the buyer to replace the product every year or two because of illusory, nonessential "improvements" like tailfins. No way I'm jumping on the bandwagon to replace my phone every two years. It may be easier to engineer a phone with a non removable battery but the decision is 99% marketing, not an engineering one.
For a lot of people, external battery packs have solved this problem.That doesn't replace the FUNCTION of being able to go from 0% to 100% any time/place you want. I have replaced hundreds of internal batteries but I am not deluding myself: replaceable != swappable
It's one of the main reasons why I will not be switching to the Nexus 6 from my iPhone 6 Plus. The other is that it has no expandable storage. If it had both then I would switch. I'd go for the LG G4 except that if doesn't work with Google Fi. I want all three if I'm going to ditch iOS again, dammit! My last phone was a Galaxy Note 3.
And it's not about being able to replace it. I replace internal batteries all the time. It's about being able to swap it. No fast charge in the world beats an instant charge. Gang charging means always having a full battery ready to go.
I don't understand how anyone can use a full charge on a modern phone in a day. Do you do anything other than stare at your phone?
I stream radio two hours every day in my car through bluetooth over data, plus general usage through the day and evening and I rarely have less than 50% of battery life left when I go to plug it in at night. I really don't get it. Do people just not charge their battery and then complain about bad battery life when it dies? Why is swapping even necessary when I work next to a computer all day? Power banks too. My car has a usb cable that I don't use, but I can to charge if I'm in a pinch. What could you possibly be doing all day that you MUST have a swappable battery?
Try sitting in an office with limited reception. It'll drain almost any battery within a work day (often by lunch).I don't understand how anyone can use a full charge on a modern phone in a day. Do you do anything other than stare at your phone?
Not any more. After overdrawing the USB power for years (phone + many pieces of equipment), my work computer no longer has functional USB ports. If I didn't work at a cheap company, I could probably have this 6 year old computer replaced. I do have a fun trick now: I can plug in a USB drive to cause the floppy disk drive to make that crunching sound until the USB drive is removed (you may remember that from years ago when you may have used floppy drives).so plug it in? doesn't your computer have a usb port?
But the same problem exists with people who work in the field without a computer to plug into. If you are someone like a HVAC repairman, cable installer, home inspector, etc. then you will frequently be in areas where you might not get good reception (and that is completely out of your control) and that is a battery killer. You have no computer handy for charging. And if you keep trying to plug it into your car repeatedly, that is a battery killer. Then you have a non-functional battery which is even worse than low battery life.
Heck, the last time I needed a part to repair my furnace, I met my HVAC guy at a Verizon store. He had 10 non-functional iPhones (batteries were all dead from his employees) and he was trying to convince Verizon to let him upgrade his fleet of phones early.
If you read my post above, I have a Droid Turbo and no need for AC outlets, Qi, or any other charging at work.You have no AC outlets? I have a Qi charger on my desk. I leave work with my battery at 100%.
