Would the boat sink?
Canai
8,016
but fish != birds and water != air. Yet the principle remains the same. What a crazy world we live in...
jagec
24,442
Originally posted by: jtvang125
If they were hovering mid air how are they exerting any weight onto the boat? Just like if you're hovering over a weight scale, would the scale move?
Because in order to counteract the force of gravity, you're exerting an equal but opposite downward force. A scale won't register it because the downdraft spreads out so much, but if you're in a sealed shipping container, well, I don't know.:)
Originally posted by: Canai
or maybe half a mole of hummingbirds even?
:confused:
Now that's a big box!:Q
jagec
24,442
Originally posted by: DarkKnight69
THe problem with this is that water weighs more then air, we are not weighing the air in this scenario. If you weighed a tank in water with water in it, would have the same effect.
oh yes we are! You don't think a container with a vacuum in it weighs less than an "empty" container full of air?
Canai
8,016
well, time to head to class and put a stop to the mindless drivel pouring forth from my mouth, er hands. Oh wait, it's a discussion class: confusing statements ftw or all!
brikis98
7,253
8
exactly... it's a complicated aerodynamics problem since it depends how the air being pushed downwards by the hummingbirds interacts with the holes at the top of the box... chances are that enough air will exit through those holes to reduce the force below 90lbs, so the ship won't sink, but who knows for sure.
dullard
25,476
3,974
Bingo. Is the box 1/2 ft high so that the pressure of the air is probably hitting the crate bottom? Or is the box 500 ft high so that the downward air isn't affecting the crate bottom at all?
ahurtt
4,283
Originally posted by: dullard
Originally posted by: ahurtt
Ok how about this. . .If you have an aquarium with 20 gallons of water in it, and then you put in a 2 pound fish, assuming the fish is alive and floats suspended in the water, not touching any sides, does the aquarium now weigh 2 pounds more?
[*]Aquarium: container + water + fish all stay there.
[*]Box: container and birds stay there, air comes out.
Those aren't the same comparison. If they were the same comparison, a flock of pelicans flying over the boat could sink it too.
But stuff weighs less in water than it does out of water. . .for example if you put a scale at the side of the pool and another scale in the bottom of a 6 foot deep pool. You weigh your self out of the water and you weigh, lets say 175 pounds. You now get int the pool and stand on the scale and weigh yourself, does it still register as 175 pounds? I think not because you weigh less in water. But lets say it were something denser than water like a solid lead sphere which weighs 100 pounds out of water. If you weigh it again in water, would it still weigh 100 pounds?
Coquito
8,559
How much does the rope weigh(that you're tying the birds down with)? What about the straps on the box to keep it secured?
Phoenix86
14,644
10
Originally posted by: FoBoT
that is BULK HUMMINGBIRDS!
So, is there some place online where I can buy bulk hummingbirds? You know, hummingbird clusters the size of an alternator?
alternator sized hummingbirds clusters are not bulk!
It's SHIP SHAPED.
And 91lbs is definitely bulk.
ahurtt
4,283
the floating objects aren't exerting any force on the boat. Infact, they are pulling the boat out of the water with the force of their gravity!! (mathmatically insignificant though).
Absolutly! You are adding to the water, increasing downward force towards the scale below the aquarium.
Even if the box was air tight, and you had 100000000000 objects floating inside it, they wouldn't effect the weight of the boat at all. All it's going to do, is displace the air around the objects.
I use floating objects in the example so people can stop talking about the downward force from their wings.
But floating objects implies that the objects themselves are actually weightless (or at least less dense than the medium that surrounds them) and so need not exert any force to remain hovering. Hummingbirds are not weightless and so must expend energy to thrust themselves upward. . .
dullard
25,476
3,974
Don't confuse bouyancy and weight. You weigh the same amount in water as you weigh out of water. Bouyancy forces, however, make the scale read differently.
ahurtt
4,283
Originally posted by: glugglug
The air movement from the birds flapping their wings creates a pressure differential between the top and bottom of the container, and this pressure differential carries a force exactly equal to the weight of the birds pushing the boat downwards.
So it sinks.
P.S, during liftoff, the downward force exterted on the air by the birds (and transferred to the boat) exceeds their weight.
Well that makes sense, assuming the birds were not hovering already when their box was put on the boat. But what if the birds began hovering first and THEN the container was placed on the boat with the birds still hoveirng?
ahurtt
4,283
Originally posted by: hiredgoons
I'd like to see a 10 lb box that can hold half a mole of hummingbirds :confused:
Well what if the box were constructed of reynolds plastic wrap and was really more of a bubble. . .you could make a pretty big plastic wrap bubble with 10 pounds of plastic wrap.
ahurtt
4,283
They are already part of the boat so they are insignificant.
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Originally posted by: Ramma2
If a hummingbird hovers above a scale, does it register on the scale?
Nope.
Does the boat sink?
Nope.
Is this lame?
Yep.
I agree, but there is a coworker of mine I have to prove to that the boat wouldn't sink. This was a stupid lunch discussion we were having.
As mugs and fleshconsumed have pointed out, this is a pretty simple physics problem. You can't "prove" the boat won't sink; because you're wrong. Your coworker is correct.
DrPizza
Mar 5, 2001
49,601
166
111
Here's a reference:
advancedphysics.org
The box would exert the same amount of force on the boat. Note that in that discussion by physics nerds that one person even points out the E=mc^2 equivalence and notes that at a higher energy state, the mass is greater. He forgot to account for a slight decrease in mass to result in this energy. Regardless, the physics nerds don't even for a moment entertain the thought that the box weighs less.
This is basic physics. A couple of free body diagrams should point out the solution. If not, your physics teacher sucked.
Oh, and the sides do end up mattering, of course.
JulesMaximus
74,528
908
Originally posted by: mugs
Considering how little hummingbirds weigh that has to be a pretty big box, and if this big box fits on a boat I would have to wonder why that boat is only capable of holding 100 pounds of cargo. ;)
That's over 13,000 hummingbirds
In a 10lb box. :laugh:
hiredgoons
84
Enough to hold ~6.0223/2 x 10^23 hummingbirds? We're talking about a "box" of hummingbirds that's probably not too many orders of magnitude off of the volume of the Earth itself.
