I would give each board a try but, let's say, that I start with phpBB on my site then at a later date switch to InvisionBoard can I easily transfer the threads between boards?
That's a good question, I'm sure it's possible but probably isn't going to be easy.
I would recommend installing BOTH forums. Play with each forum (before going "live") and decide which you like better.
But the web host has to offer Fantasico too, right?
Wrong. All Fantastico does is makes installing 10x easier and quicker. All your web host needs is a control panel and MySQL/PHP. If they have those two but DO NOT have Fantastico then you will need to do a "manual install". Brief installation instructions are included with phpBB and InvisionBoard software packages which you download directly from their respective web sites.
I don't think that I would like to tackle that right now...I have no idea how to:
1) create a MySQL database.
2) You don't have to CHMOD any files or folders.
3) You don't have to run the install/configure script
Then I will gladly offer to install both forums for you and show you how do it as well
There is no rush because the HostPC $15.98/yr package should be around for a while.
Do either of those boards offer the feature to add a poll to a thread?
Yes, both forums support this.
Lastly, for now , would it take much programming to add pictures, in the same manner as ads are on somthis board, to the forum pages of InvisionBoard?
Nope, no programming is required. This is a feature which is already enabled (just like polls are).
Regarding these last two questions (polls and pictures) why not try it out yourself?
Login to
the forums you created, start creating new threads, add polls, add pictures, screw around with it. Don't worry you won't break anything
Trust me installing your own forums is VERY EASY and I can show you how to do it, step by step.
