Originally posted by: PascalT
I tried every other inputs and nothing works except that one in 2 speaker mode...
Is there a speaker test in the control panel for the sound card? Run that and see if sound comes out the correct speakers.
yea there is but the only way sounds comes out is with the 2 speaker modes enabled and the speakers plugged into line in or the center/bass one
yea it shows fine. In 2 speaker mode it shows the front speakers working and in hi-sample rate it shows them as the rear ones.
it shows 44.1khz in the sample rate on the right, should it say that or 48? it showed 96 earlier
yes i am using the black one next to the digital output, and it sounds pretty good. I am using high sample rate as well.. so all is good 😉
yea i did.
My cpu usage is going nuts here, going from 8-60% all the time. It never happened before this.. Should I just use the normal line-out? I also did the jumper changes on the card to skip amplifying the sound twice.
here's one.Originally posted by: PascalT
how do you get the asio output to work? I couldn't find the plugin. I have ASIO4ALL..
Nope, pretty much what you'd expect for the asking price.are the Klipschs really that amazing?
