The GTX 460 has a base clock of a puny 675 MHz (with tons of room to grow). The GTX 560 has a base clock of a beefy 820 MHz, or 21.5% faster!
Regarding shader power, the GF 104 just has 1 more shader unit, pushing the shader count from 336 to 380, an increase of 13% in shader power.
Any good deal on a GTX460 1GB or 768?
WOW, with those calculations ,the stock gtx560 should be about 34% faster then a stock gtx460. So a gtx460 @ 910 core should about equal a gtx560.
Thats puts the gtx560 at 5870/6950 territory at stock clocks going by this review.
http://www.anandtech.com/show/4061/amds-radeon-hd-6970-radeon-hd-6950/18
On newegg the 6950 goes for about $280AR, and the 6870 goes for about $210AR. So with performance at a few% below the 6950, the gtx560 should be priced at about 260$?
I think is fair to say th gtx560 will be worth about $260, given todays card prices.
The gtx460 and 5870 are priced so low because they are being ELO'ed.
@castiel
It's a fake, it's GTX 460, not 560.
How can you tell? They're identical![]()
maybe because dealing with 4 gpus in crossfire is not the best experience.OP, why are you going from quadfire 4870s? which was a bad choice to begin with to SLI 460s? Thats a sidegrade at best.
Why not get 2 570s/6950s/6970s? They wold give you a nice boost in performance.
Also, I don't see the 560 competing with a 6950 with that amount of memory bandwidth.
2 gtx460's in sli vs 4870x2 in x-fire?
Less heat, less noise, less power draw, less quadfire headaches.
I bet if you overclock the 460's you get better performance also.
Sell the 4870x2's for about $280 and its a 70$ upgrade.
I think he did good.
GTX 460 is a good deal if you are into OCing, but IMHO AMD 5xxx or 6xxx series are slightly better if you stick with manufacture speed.
IMHO, it is going to be hard to get the GTX460 to 1GHz specially the 1GB version. I'm lucky enough to have an MSI Hawk Talon Attack that break the 1GHz barrier, but I have to dial it down to 900~950Mhz to get acceptable fan speed (still noisy as hell at 950Mhz).
