worth going from ATA to SATA2 or 1??
Jules
Was wondering if it really made a big differnce from regular ata to SATA2 or 1?
Ricemarine
10,507
Nope. Only if you need more space by running out of ports.
Jules
cool so not worth going from regular ata 250gb hd 8mb cache to a 250gb Sata?
F1shF4t
1,583
Its not worth UPGRADING, but if ur planing on buying a new drive go for the SATA interface for sure.
Jules
problem is i already have a 250gb 8meg and just wanted to got 250gb Sata but it seems its not worth it.
Bobthelost
4,360
It's not worth swapping out a 250gb PATA drive for a SATA drive, but i'd go for SATA for future drives when you need more room.
LumbergTech
3,622
if you are adding an ADDITIONAL 250 gb hd then i would say yes get an sata drive if you already hve the sata ports etc .....but if you are referring to replacing your current 250 gig with an sata, no it isnt worth it..
Blain
Didn't you read what he said?
Budman
nope he's got a stupidmouth. ;)
Googer
12,576
7
Not much diferance and some drive models actully work better on PATA than the same model useing SATA.
kd2777
1,336
QFT
The only advatage (other than a longer ecock) is the cables. They are easier to route, look better, and don't hamper air flow as much.
kd
