mfenn
I wasn't very clear... i mean, most web stores here sells a lot of ECC buffered kits, but not many unbuffered ECC ones. The only one i could find is a CL11 1600mhz Kingston kit (which is ok since it is also on the qualified memory list for the MB)
Link us to some Italian web shops that you use and we'll help you find some good memory (you don't necessarily have to buy a kit).
Also, if you're considering an 1155 workstation build, make sure that you are looking at the Xeon E3 processors instead of the i5/i7 processors since the E3's are the ones that support ECC.
