Rubycon
Madame President
- Aug 10, 2005
- 17,768
- 485
- 126
For those that NEED that power heat dump is of secondary concern.
I've heard these pumps and personally on the issue of noise I think that is way overblown. Properly mounted even at 26 volts (we've gone as high as 30!) the sound was not bad at all. The pump at 17V was actually more objectionable with a lower pitched tone.
The pressure they put out is very impressive. You have to be careful of the fittings you use. Conventional SLI fittings (slip type) can actually allow the cards to spring apart and the fittings leak! Acrylic topped chipset blocks show stress cracks around the screws from flexing. Granted this system was running four MORA 9x140s.
D5s are pretty nice but be very careful not to even let them slurp (insufficient water) for long, let alone run dry even for a second or the graphite bearing will be destroyed. The RD series can tolerate this abuse and not miss a beat.
