- Jan 6, 2002
- 373
- 0
- 71
My build is already in progress and I completely forgot that I had an an account here so I'd figure that I would finally start posting so enjoy the pictures and the commentary
Hardware List:
Hardware:
Intel Core i7 2600K - replaced AMD Phenom-II X6 1090T - New addition
Gigabyte GA-Z68X-UD7 - replaced Gigabyte GA-990FXA-UD7 - New addition
16 GB (4x4) Kingston HyperX Grey series DDR3-1600 - replaced 8 GB G.Skill Trident DDR3-1600
Powercolor Radeon 6990 4GB - replaced dead Sapphire Radeon 6950 that caught on fire
Sapphire Radeon 6950 2GB flashed to 6970
KillerNIC 2100
SB X-Fi Titanium HD PCI-Express - New addition
(2) Intel X-25M 80GB in Raid 0
(2) Seagate Barracuda 1TB 7200 SATA
(1) Seagate Barracuda XT 3TB 7200 SATA - New addition
5.25" to 4 3.5" SAS/SATA Hot swappable bay
LG Bluray-RW SATA
Corsair AX 1200 - replaced Enermax 85+ 1050 Watt PSU
Case Labs M8 - replaced XSPC H1 Cube case
NZXT Sleeved Orange LED kit - replaced White LED kit
MDPC Sleeving Titanium Grey and Orange
MDPC Black Heatshrink
MDPC Cable management clamps
Water cooling hardware:
Koolance RP-402X2 with (2) PMP-400 pumps - RP-402X2 replaced by below items
(2) EK Multioption 150 Advanced Reservoir
(2) Koolance DDC pump tops
(2) Koolance DDC Heat sinks
Aquaero XT 5 with (2) PowerAdjust 2
Koolance HX-CU1020V 360mm Radiator
Koolance HX-CU420V 120mm Radiator - removed
EK CoolStream XT 360mm Radiator - New addition
Phobya G-Changer 360mm Radiator
(16) Xigmatek Orange blade/White LED 120mm fans
(6) Enermax White Cluster 120mm PWN fans - replaced by fans above
(1) Enermax Red Cluster 120mm fan
(9) Xigmatek Octane 120mm fans
EK Supreme Full Cu nickel plated CPU block - RMA'ed with EN version
EK Gigabyte 990FXA-UD7 block
EK 6970 full cover block with EK back plate - Both blocks replace the Swiftech blocks
EK 6990 full cover block with EK back plate
(20) Enzotech G1/4 (3/8" ID x 1/2 OD") compression fittings - New addition
Various BitsPower and Koolance fittings
(4) Sets of Koolance VL3 3/8" ID QDC fittings - New addition
Aqua Computers in-line temperature fitting
Aqua Computers flow meter
15 Ft. Tygon 3/8" ID tubing - replaced 10 Ft. Masterkleer 3/8" ID tubing
(5) ModMyToys 3-pin power distribution PCB - 5-way block - New addition
(5) Hammond ABS Project Boxes - New addition
The build has evolved quite a few times starting with a CM HAF-X to a Silverstone FT-02 then an XSPC H1 Cube, finally settling on the Case Labs M8.
Hardware List:
Hardware:
KillerNIC 2100
LG Bluray-RW SATA
