AFAIR, silver coils and nickel plated components should not be used together.
meh... its actually a mix bag... depends on what the nickle coating is actually made of.
Back when vendors didnt cheap on nickle, and swiftech was heavy on the chrome, it was safe.
However now they cut every last corner possible, and yeah, nickle is kinda dangerous with silver, as you don't know the other alloy.
But the reaction between nickle and silver is very low, and at worst what it does is just strips it, but you wont see corrosion on the level of alu + copper.
I still use nickle and silver because i really dont care what my blocks look inside derlin, i only care that the outside doesnt tarnish like copper does.
I seem to remember some guy's use to just use Distilled water and a teaspoon of Bleach.
Bleach??? we dont use that... bleach can play havok on your Tubing. If you dont want to use silver, you can always use cupramine.
https://www.amazon.com/Seachem-6710...s=copper+safe&qid=1551429872&s=gateway&sr=8-4
like 3 drops should be good.... or you can use PT nuke....
https://www.amazon.com/Petras-Tech-...words=pt+nuke&qid=1551429987&s=gateway&sr=8-2
Personally id use Cupramine over PT Nuke...
That sounds like a really bad idea on the surface, bleach works by liberating chlorine gas,
Nah the Chlorine would eventually evap out though the tubing unless your running 100% rigid.
Chlorine also has no impact to rubber or silicon seals.
What it can do tho is make your clear plexi yellow, strip the dye off tubing, or making your tubing turn yellow quickly.
Edit 2, searching the entire subforum for "bleach" also brings up mostly rather old posts
Probably before the days of using copper 2 sulfate or cupramine.
Copper 2 Sulfate comes mostly from swimming pools, while cupramine comes from fish tanks.
Both are antimicrobial, and will work, just use it very sparingly...
