Can you do normal grip pull-ups? If so how many?
Work on negatives, jump up to the top and slowly lower yourself. Careful with these though, I'd say do a few sets of 5 and see how you feel, the slow eccentric will cause massive DOMS (muscle soreness) if you are not careful with it.
I can only do 4-5 chins ups currently.
I thought you were supposed to lean back slightly with lat pulldowns.
It's too easy to cheat with a lat pulldown by leaning backward or employing your lower body in a way that gives you a mechanical advantage...
Cheating is on you, not the machine![]()
Nothing is better than a Lat machine because it lets you do 5x5s either progressively or not (whichever stage you are in). Like always, form is important, and try not to use your biceps...
its a poor substitute for the pull up. do the real thing instead, leave the retarded lat pull down for warmups and cool downs
It has it's place imo...
The bulk of the OP's training should be jumping with eccentrics but he can't even can barely do 1-3 he needs to work on his lats.
He should use the lat pull down to work on this. MOST people can't do a strict wide grip pull up for 6 'clean' reps that go all the way to the bottom. He should use a lighter weight and focus on starting the pull up with his lats when on the lat pull down machine.
I do about 3-4sets after a maximum set of wide grip pull ups.
Koing
Why do you want to do wide grip pull-ups?
How much of a carryover is there between the lat machine and pull up? Also, what are the cues to be able to start the pull with only the lats?
Speaking of which, what is your height/weight? It may be more of an issue of you weighing too much than you not being strong enough, but I don't really know.
Plus, guys who can usually crank them out effortlessly are a bad ass.
