Originally posted by: DBL
Originally posted by: Lucky
It works on film cameras...but with severe vignetting from the 12-18mm portion of the zoom. Beyond that it's OK I hear, but its optically designed for the D series of digicams.
Thanks for clearing that up but you would have to be crazy to drop $1200 on a 12-24mm lens in order to use only the 19-24mm range. There are better options out there.
I'm not sure you understood my situation. My widest lens at the moment is a 24mm (which is a 36mm on the D1). So, I'd be gaining the 18-36mm range, effectively. Other solutions would be to buy a 14mm prime lens and a 20mm prime lens, but that still would only give me ~21mm at the wide end and I'd be lugging around an extra lens (and be paying the same price as the 12-24 in the end).
Don't forget that I will be using this lens professionally so anything that can help me make better images can help me make more money.
