On one of my Networks I use a different approach.
I leave one computer in deep sleep (it takes less than 10 watts when it sleeps).
This computer has UltraVNC installed as a service with none standard port open to the Internet set with AES encryption and strong PassWord.
The computer 's NIC is set to get it out of sleep On any LAN traffic.
I have the UltraVNC Viewer on Key Chain Flash Drive (no need to remember the PW since it is with the VNC in AES encrypted key).
Sticking the Flash drive to any computer with an Internet connection and starting the VNCviewer would wake the Sleeping computer through the Internet.
Once it is up and running (takes about 10 to 15 sec.) I can do what ever I need on my LAN (including using WOL as a local process) all is done safe through AES encryption from a Flash Drive that does not leave any info on any computer.
P.S. This is what the viewer is consist of.
vncviewer.exe - The VNC Viewr program file
MSRC4Plugin_NoReg.dsm - The AES Encryption Module
rc4.key - The Encrypted Encryption Key
Three files about 1MB in size would run from a flash drive on any Windows based computer, and connects you from any Internet connection in the world.
