Originally posted by: Harvey
Vonage's FAQ page says their system should work with almost any decent router:
· I already have a network in my home. Will I be able to subscribe to vonage service and use my existing networking equipment?
Vonage will integrate with most networks very easily as long as the Vonage device has open access to the Internet.
Simply plug the Vonage adapter into any Ethernet port in your network that can access the Internet with open connections. There is no need to specifically forward ports to the Vonage adapter, it will make standard connections like any of the other computers on your network.
Note that some corporate firewalls "close" certain ports, or prevent those ports from being used to access the Internet. In order to function properly, Vonage adapters need open access to the Internet.
The Linksys WRT54GL should work well. If you want to save some money, Newegg also has this
Asus WL-520gU for $34.99 after a $10 rebate. I don't know if the added $5 discount code,
EMCLVNR45 is still active. If it is, you'll save even more.
I know this model works at least as well as the Linksys because I set it up for a friend. It was extremely easy to set up, and it's been running continuously without problems since February. User reviews on Newegg's site agree with my experience.
Getting a laptop on the network is as easy as bringing it close and pushing a button on the back of the router.
