I have two wireless routers that both give the same results:
When i connect to the device with a cable, everthing works perfectly, but when i try to connect wirelessly, the computer does not recieve tcp/ip data from the router so it just configures an internal address. I tried configuring the tcp/ip manually, but even though it said connected, IE would not load any pages.
Any ideas. is the internal wireless card bust or something???
Thanx
Thanx
