Omnidirectional antennas, "vertical beam width" (I usually see them at ~15 degrees). What does that mean? If that's what I think it is, an omnidirectional antenna isn't really omnidirectional because it dosen't radiate the signal 360 degrees in the form of a sphere.
Extending wireless coverage, Going with a repeater solution dosen't really work since I read it cuts power in half or something. How about having two APs connected to the same switch? What my question is, how will a wireless client handle having two access points with the same SSID and channel in the same area?
