Wireless Network...word up
GSOYF
510
A Client card for each machine, plus a central access point.
Something like the Linksys WAP11 would work quite well for your AP - $134.99 @ CDW
2 x Linksys PCMCIA Client Card - $82.28 @ CDW
If you intend on using the PCMCIA cards, you'll need a PCI adapter for each- $45.99 @ CDW
would this be sufficient ...don't feel like having to get the adapters.
linky
Beau
17,730
www.beauscott.com
linky
Those are just PCMCIA -> PCI adapters. You have to have one to use a wireless card in you PC (unless you use a USB client). They have the same adapter card on that page for $25.
FoBoT
63,084
15
fobot.com
...also..how does the bandwidth compare to using wires....is it decreased at all with wireless??
its slow, but if you only use it for email or web surfing, slow is ok
don't forget security, many wireless systems are insecure by default, if you don't set it up correctly, any body in your neighborhood or driving by in a car will be able to access your LAN
GSOYF
510
but that Orinoco bundle only comes with 1 card.... I would have to get another wireless card for the other computer......right???
[its slow, but if you only use it for email or web surfing, slow is ok
don't forget security, many wireless systems are in-secure by default, if you don't set it up correctly, any body in your neighborhood or driving by in a car will be able to access your LAN [/i]
Not really worried about that...i'm not doing anything remarkable on my pc
just to clarify I assume the access point connects to the cable modem via rj45 cable??
RossMAN
Grand Nagus
Feb 24, 2000
79,103
462
I have found the best PC cards, the Orinoco Gold for as cheap as $50 on eBay plus shipping & handling.
GSOYF
510
do they make wireless pci cards or do you have to get a PCMCIA + adapter??....or USB obviously.....
rallispec: 11 mps/sec. still faster than the cable modeM
I am confused by this statement...don't you still need the cable modem in addition to the access point??
