Wireless Network with Hardware Firewall
Space Cowboy
255
I want to install a wireless network but I don't know anything about it except that I will be buying Linksys hardware.
Is there such a thing as a wireless box with a hardware firewall built in?
WHich one would be the best to get. I think the max computers using it would be 3.
Can I do something like this?
Cable into Cable Modem then out to wireless router (with hardware firewall) out from there to Main computer via ethernet cable. Send signal upstairs to a laptop and 2nd desktop?
Thanks Gang
Cowboy
InlineFive
9,599
All NAT routers incorporate a "sort-of" firewall in them for the WAN zone. It uses NAT to allow and disallow traffic into the network based upon the internal computer's requests. If you spend a little more (about $50) you can buy a higher end WRT54g/s model which incorporates a more intelligent SPI firewall.
As far as client adapters goes you won't find a firewall. Your only option will be to settle with a software firewall.
JackMDS
29,545
422
Wireless Cable/DSL Router get connected to the Cable Modem and than cab be connected via wire to 4 computers and many Wireless computers.
If you have problem in understanding or settin the system this might help.
Link to: Diagram of Broadband Connection with Cable/DSL Router.
Log to this page it has a lot of links to instructions to Windows Network Setting and Sharing.
Link: Installing & Sharing
Link to: Basic Protection for Broadband Internet Installation.
Link to: Freeware Security suit for Internet Connection Protection.
Link to: Wireless What Should I Get?
Link to: Wireless - Basic Configuration.
Link to: Wireless Security.
:sun:
JackMDS
29,545
422
My personal perference:
Best stability, performance, Windows compatibility, and good price, this:
Link to: Buffalo Bundle. (if this link does not work log to newegg.com and look for a Buffalo 802.11g bundle).
Best price to speed deal is this Router Client Card combo:
Link to: D-Link SuperG Bundle.
D-Link QA is not the best. Some time poeple would need to RMA inorder to get a Good Unit. Buy when it works it works well
Some people like to buy the Linksys WRT54G and hack it.
You pay $59 for the Router + $50 for a Cardbus + $20 to the hackers.
That is about $130.
The hacking unit, if successful, provides WDS and extra power to the unit.
The Buffalo is WDS as is for. So to pay $40 more for Linksys bundle void the warranty and risk frying the unit (which might happen with the Linksys on Extra power).
Nah! I would stay with the Buffalo. :thumbsup:
:sun:
