I just bought a WRT54GS in an attempt to set up an access point for my Wii and DS while living in a college dorm. I'm sure it would be a breeze to set everything up if it wasn't for this resnet Cisco systems network.
1) If I connect the router normally, as in Internet->Router->PC, I lose the ability to connect to the internet, because I keep getting redirected to the Cisco login page.
2) If I change the setup to Internet->1st Network Card in PC->Router(via second network card), I can connect to the internet if I connect the ethernet cable from the PC to the 'internet' port on the WRT54GS, but lose the ability to use the router(it seems to only send packets to the router, but not retrieve any packets(according to control panel->network settings, etc)). If I connect the ethernet cable from the PC to a number output on the router, I lose the ability to connect to the internet, but gain the ability to communicate with the router.
Any help would be much appreciated, thanks.
