Rubycon
Madame President
How do I do these file transfer tests?
For years I've used Netpersec. You can download it here:
http://download.cnet.com/NetPerSec/3000-18512_4-15690.html
Yes with 5GHz it's possible to hit 200Mbps (actual) BUT your range is quite limited. Those speeds drop very fast once you distance yourself even a few meters out.
I just got a Linksys E4200. The PC is an Acer laptop with an Intel Centrino Ultimate-N 6300 wifi card. I'm using the E4200's 5GHz radio and Windows shows 405 to 450Mbps up to 40ft. away with walls in between.
I know what Windows shows isn't a reliable indicator of the actual network speed, but for the first time ever, Windows is showing the speed of up to 450Mbps. The highest I ever saw on a Linksys E3000 was 250 to 300Mbps.
I also have a Linksys WET610N wifi bridge on a TV downstairs and before with the E3000, the 5GHz signal was only around 30%. With the E4200 the 5GHz signal is now around 65%.
