Hi, I currently had a couple of external hard drives wired to a powered usb hub, which is wired to the usb port on my laptop
I want to do one of two things, one of them is (probably?) easier.
Either I want to wirelessy connect the USB hub to the laptop, or I want to wirelessly connect a single external hard drive, to the laptop (the external hard drive would have it's own mains power supply)
a standard 1TB 2.5" hard drive will set me back about £45, which is fine.
doing a search for bluetooth hard drives seems to put them in the £150 area, which isn't preferable. also do bluetooth hard drives go for 'complete' portability and use their own battery power? (not preferable either)
basically ideally I want to find a way to wirelessly connect my usb hub to the laptop, I'm not sure if this is possible. the range doesn't have to be more than a few metres. Hope I've asked that question clearly
