wireless bridge with 2 wrt150n
cganesh75
Elite Member | For Sale/Trade
9,540
33
101
hey guys... due to the weird layout of my house and stupidity of the bellsouth/at&t i can get DSL only in 1 phone outlet. i have a wrt150N router hooked up to it. unfortunately my htpc and fileserver are in a different room. currently i have the following setup
WRT150N ---<wireless>---- wrt54g(as wireless bridge) ---> gigabit switch --> server, htpc etc..
obviously my server and htpc are limited to 54Mbps because of the wireless G router. Now my question is, if i were to get another 802.11n router (another wrt150N) and use that as a bridge insted of the wrt54g will i be able to get wireless N speed across? i would like to know this before i make any purchase...
Thanks
Madwand1
3,309
Yes, by installing DD-WRT on the device, and running it in client bridge mode.
Note however that "54 Mb/s" and whatever draft-n claims are exaggerations. Standard-g will cap at around 23 Mb/s actual transfer speed under ideal conditions (which are rarely reached), and draft-n might do something around 50 Mb/s actual transfer speed under good conditions. There's absolutely no way it'll hit the marketed "270 Mb/s", or whatever for actual transfer rates.
Edit: The WRT150N is compatible, but is no longer easily available. If you want to get something else, first check the model and revision on DD-WRT's supported hardware list carefully -- check the notes to see if it's fully supported or a "work in progress". The latter means it's not really supported, but you might get lucky in the next year or so...
cganesh75
9,540
33
101
thanks.. all my routers are dd-wrt flashed now. i am just looking for a higher transfer rate to stream HD content
JackMDS
29,531
416
If the WRT150N can work as a bridge try it.
I.e., reverse the roll of the 150 and the 54.
cganesh75
9,540
33
101
reversing the role is fine. but i want to stream hd content between pcs hooked up on both routers. if i have wrt54G at either end, i am gonna end up with 54Mbps max traffic right?
JackMDS
29,531
416
It might be better since Higher Steam might pass the Bridge.
cganesh75
9,540
33
101
i dont understand what u mean...
cganesh75
9,540
33
101
just wanted to update. i got another wrt150N. setup one as an AP and other as client bridge. it works like charm. this method also improved transfer rate in a laptop that only has a wireless G card.
