Topic sounds simple, right? Well, maybe not. You be the judge.
Router is a "BEFW1S4 v4" Linksys wireless-b router. Not great, but it was a gift, so I don't complain. I've upgraded the firmware to the latest version.
The network adapter is a "WUSB11 v2.8" Linksys USB wireless-b adapter (also a gift), and I am using the latest driver for that.
The computer is running Windows XP Pro w/ SP2. I've also grabbed all the latest high priority Windows updates, and didn't see any other updates related to wireless networking.
The issue is that I've setup WPA Preshared Key encryption on the router and the computer. Everything connects and seems to work fine for a liitle while. I've got "excellent" signal strength. Heck, the wireless adapter is probably no more than 20 - 25 feet away in an adjoining room. I don't have any other 2.4 GHz devices (i.e. my cordless phone is 900 MHz), and I did not place the router near any sources of interference that I was able to identify. Problem is that the wireless connection "dies" anywhere between 10 minutes to 3 and a half hours. When I say "die", the connection just quits, but Windows doesn't realize it. It says I'm still connected, although the connection duration in the network adapter stats has stopped ticking.
I know that WPA encryption is very sensitive to signal strength, but I'm getting "excellent" signal strength, so I doubt that's the problem. The router is set to channel 1, and I've also tried channel 11 with the same results. I don't use channel 6 because I have a neighbor downstairs who uses channel 6 (and all the default settings). Heh. I've tried to warn my neighbor about that, but she doesn't get it. But I digress...
The network is fine if it's unencrypted, but I don't want it unencrypted. Anyone got any ideas? Thanks.
MoonSword
MoonSword
