ivwshane
Here is what I'm trying to do:
My main router services my wired network and my wireless network down stairs. I have a secondary router that I want to service my wireless clients upstairs.
I have a hard wired connection into the secondary router and I just need it to be an access point using the same SSID and password as the primary router so that moving from downstairs to upstairs is seamless as far as a wireless connection goes.
I'm trying to avoid the bandwidth reduction you would normally get if you simply repeat the signal (since half of the bandwidth is receiving and the other half is transmitting).
So how do I need to set this up on the secondary router using DD wrt?
I thought setting it up as a repeating bridge would work but if I turn off wireless on the primary router there isn't any wifi to be found.
I have the secondary router plugged into a switch using the routers LAN ports.
