Wired garage door keypad
Status
Not open for further replies.
MotionMan
17,124
12
I had to do some work on our garage door opener this weekend and "rediscovered" that we had a wired, keyed opener (on the side of the garage) not unlike this. I say rediscovered because, in the 4+ years we have lived here, we have never used it and, in fact, I do believe we ever had the key for it (and if we did, it is long lost).
I want to replace it with a wired (not wireless), keypadded opener. Unfortunately, Home Depot and True Value near my house do not have these.
Also, the ones I have found online have a "ribbon" wire. I am looking for one that connects to a 2-wire set-up (like the one above with the 2 screws).
Does anyone have one of these they would recommend? Where did you get it/can I find it?
MotionMan
arcenite
10,660
7
I just bought a house that has what you are looking for.. and I wondered what prevents someone from taking it off the wall and connecting the wires together.
bruceb
8,874
111
Try this one:
http://www.stardoorparts.com/Domino_GD_1_Hard_Wired_Universal_Keypad_p/den%20rc gd-1domky.htm
MotionMan
17,124
12
Probably nothing more than a screwdriver or brute force. ;)
MotionMan
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
Does your opener accept wireless? If so, why would you want wired?
Vincent
I use our keypad opener all the time. It's not convenient to have a remote with you all the time. Maybe I'm taking the dogs out through the garage and want to close the door behind me without having to carry the remote on our walk. Or I'm working in the front yard and need to get a tool from the garage.
MotionMan
17,124
12
I never have a remote with me. Both of our cars are programmed with the remote code. There have been many times when I had to open the door, turnoff the alarm and fight off the dogs just to get something out of the garage. IT would be a lot easier if there was a secure exterior way to open the garage.
BTW, its location is pretty well hidden from the street - you would have jump our gate in order to even know it was there.
MotionMan
ElFenix
102,408
8,596
they make wireless keypad openers
unless it's already wired like motionman's apparently is, i'd install a wireless.
bruceb
8,874
111
Here are the specs for what I linked to. As you can see, it will work with any of the door opener brands listed here .. and it is a 2 wire connection from the remote to the opener.
Domino® GD-1 Hard Wired Keypad for Liftmaster, Sears Craftsman and Genie Garage Door Openers
  • The Domino® GD-1 Hard Wired Universal Garage Door Opener Keypad is compatible with all garage door openers.
  • Features:
  • Battery operated eliminates incompatibility with garage door openers
  • Easy to program in three simple steps
  • Hinged lift up cover protects keypad when not in use
  • Back lighting for nighttime operation
  • Low battery warning indicator when lights dim
  • Additional garage door activate button on control box
  • Uses a 1 to 6 digit PIN number providing over 1,000,000 code combinations
  • Tamper lock out after five incorrect entries
  • Mounting screws and connection wire supplied
  • Technical:
  • Power: 3 AA alkaline batteries (included)
  • Output: 1 amp dry contact relay
  • Codes: 1 to 6 digit PIN user selectable
  • Dimensions: Keypad 5 x 2 x 0.6 inches, Control box 3 x 4.5 x 1.4 inches
  • NOTE: This unit will require a two conductor bell wire to connect from the control box to the garage door opener or the garage door opener's wall mounted push button that is NOT included. We sell the bell wire separately and it can be used for the garage door opener wall button or photocell. To order 22 gauge 2 wire bell wire in a 95' spool (part number 35265B), please click here.
Modelworks
16,240
7
nothing usually. It is a really big security flaw in a lot of the systems.
You can avoid that by using a multi-wire setup where the keypad contains a microprocessor that sends a string of characters to a microprocessor located inside the garage which then triggers the door If shorted outside all that happens at most is a damaged microprocessor. Two wire systems are also battery powered on the keypad so something else to consider.
Status
