Wire Sleeving
It will... depending on what color sleeving you use and what color ligths (are you going with black-lite's?) it could have a radical effect... I use basic black sleeving on my systems, and no windows, so it doesn't really matter there...
Originally posted by: digitalsnare
yeah, i think thisll make everything look much neater, esp with the 4 UV lights ill have burnin
Once you start you'll want to sleeve everything!
I should be getting the rest of the stuff I need to complete mine tommorrow, but with what I have done so far the results are dramatic.
Is anything else in your case UV reactive? None in mine was initially. I wound up pulling all my Panaflos and replaced them with LED UV reactive fans. Did the same with my round ide cables. Right now I am clear coating over the green flourescent paint I shot on my slot covers.
When I first turned on the UVs They looked pretty dim, but with UV reactive items in the case It really pops out at you! 🙂
BTW- I am only using a dual inverter.
I thought flexo sleeving simply fits over everything and then you tighten it, you still need to take out the molex connectors for it to work?
Unless you want to use really oversized sleeve you have to remove the connectors.
Google "sleeving guide". You'll find a bunch of guides that'll work ya through the process.
